The way this forum works is that you ask a specific question and provide supporting information including the source file of your program and a diagram showing how you have things connected, both provided as attachments using the Attachment Manager that you get by using the Post Reply button. You also need to provide a meaningful thread subject, not something like "noob plz help". You can update your subject by using the pencil icon above your first message.
Once you provide useful information and a question, someone or several someones will make suggestions or ask for more information. You need to follow those suggestions and provide some feedback about what happened and possibly ask more questions ... and the cycle will continue until you're satisfied with the outcome.
To post your code, use the little CODE button at the beginning and end of your pasted code. The CODE button is located below the assortment of emoticons (funny faces ) near the top of your screen (visible when you are writing a post).
Using the code button keeps your code with the proper formatting, like this:
Repeat {Do something} Repeat {Do something else inside the previous Repeat loop...}Welcome to the forum.
