Lissajous Patterns
Years ago people discovered that you can create nice shapes using the XY mode of oscilloscopes and function generators. Now it's easy with ViewPort and the Propeller. Check out this screenshot:
This code uses ViewPort to let you choose between drawing a circle, a spinning coin, or drawing arbitrary shapes. Read more here:
en.wikipedia.org/wiki/Lissajous_curve
Here's the code:
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
Here's the code:
* (C) 2009 myDanceBot.com, Inc. *
* Use the XY plot to analyze two channels *
* AppletImage=time.gif *
This program shows how you can use ViewPort's XY plot
to plot different Lissajous patterns as generated by
the Propeller.
http://en.wikipedia.org/wiki/Lissajous_curve
This spin program produces 3 different signals which you can analyze.
When ViewPort connects to this program, it will display
the signals on the "analog" view. The xy plot graphs the
screen's worth of data from the two channels.}
CON
_clkmode = xtal1 + pll16x
_clkfreq = 80_000_000
clk8192=_clkfreq/8192
OBJ
vp : "Conduit" 'transfers data to/from PC
pub run|ch1,ch2,mode,a,b,phase,hz1,hz2,n,m
'setup viewport
vp.config(string("var:ch1(min=-100000,max=100000),ch2(min=-100000,max=100000),mode,a,b,phase"))
'send 2 channels as longs and receive mode,a,b,phase parameters
vp.config(string("dso:view=[noparse][[/noparse]ch2,ch1],timescale=20ms/div")) 'view ch1,ch2 in dso view at 5ms/div
vp.config(string("edit:mode(default=0,mode=slider,label=[noparse][[/noparse]circle,spincoin,custom]),a(default=1,mode=text),b(default=1,mode=text),phase(default=2048,mode=text)"))
' edit mode with a selector, other parameters with textbox
vp.config(string("start:analog")) 'start in the analog mode: shows spectrum analysis, xy, and oscilloscope
vp.share(@ch1,@ch2)
hz1:=10
hz2:=2
a:=1
b:=1
phase:=2048
repeat
n:=cnt/clk8192*hz1
m:=cnt/clk8192/hz2
case mode
0:ch1:=sin(n+phase) 'generates a circle
ch2:=sin(n)
1:ch1:=sin(n+phase) 'generates a spinning coin
ch2:=sin(n)/$100 *sin(m)/$100
2:ch1:=sin(a*n+phase) 'generates a pattern dependent on a,b and phase
ch2:=sin(b*n)
pub sin(x) | y, q ' x is 0 to 2^13 (0 to 8191) for 0 to 360 degrees
q := (x >> 11) & 3 ' two highest bits of 13 are the quadrant, 0, 1, 2 or 3
y := (x & $7ff) << 1 ' 0 to 90- degrees, are contained in 11 bits, shift left one for Word offset
' this is the address offset into the sine table in hub rom
' note: the parentheses are important for operator precedence
case q ' select quadrant 0,1,2,3
0 : result := word[noparse][[/noparse]$E000 + y] '
1 : result := word[noparse][[/noparse]$F000 - y] ' 2049 angles, 16 bit sin(angle) values corresponding 0 to 90 degrees.
2 : result := -word[noparse][[/noparse]$E000 + y] ' the same table is folded over and mirrored for all 360 degrees
3 : result := -word[noparse][[/noparse]$F000 - y] ' value returned in the range of -$ffff to +$ffff
return
Have you seen Sparkfun sell a generator which creates a clock? I wondered how that was done - but your post kinda explains that.
http://www.sparkfun.com/commerce/product_info.php?products_id=9306
James
Style and grace : Nil point
Years ago I worked on radar systems that used "penetron" tubes. These were huge round radar CRTs displaying aircraft dots, maps and text using vector graphics. Colour was achieved by having layers of different phosphors on the front. Winding up the electron beam voltage caused it to penetrate to deeper into the layers and light up different colours.
en.wikipedia.org/wiki/Penetron
I was thinking there would be even more screen time without the frame blankings
I like the "clock" idea! Who wants to give it a try?
Hanno
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
Want to·experiment with the SX or just put together a cool project?
SX Spinning light display·
Want cheap wholesale electronic parts?
Transistor parts wholesale
