"digital pattern generator" on the Prop anyone?
Hi!
Just one of my ideas ...
I had a look around for a signal generator. The best thing I could find was one of the RIGOL DG 2000 series. But after having a look at the manual (in original Chinglish) and at the price, I thankfully said "NO"!
This generator has quite an unique feature (except you compare it so some 10k$++ Agilent stuff):
It can send 16(?) bits with a defined pattern. That pattern is editable. It also has special patterns like RS232, I2C and SPI. Can only send sequences without listening to a response (except a trigger), but for degugging, that would be a big step forward.
Also has adjustable output (IIRC 3.3V .. 5V) except for RS232 that is something like -/+5V.
This sounds like an ideal candidate for a Prop! The UI in SPIN (or C
) shuffling data out by a COG. An other one watching for triggers, etc. Data could be a precomputed table. The RIGOL makes a constant 20(?)MSh-stream.
One point that I don't know what chip to use is the output drivers. Fast (20MHz minimum, rise-time adjustable would be an extra bonus) preferably short circuit-proof, can sink and source at least 20mA and with an variable supply voltage (up to 15V).
If someone steals my idea for the Parallax contest, I'd be glad. No really, I fear that I don't find the time for it.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
Post Edited (Nick Mueller) : 11/12/2009 9:08:00 PM GMT
) shuffling data out by a COG. An other one watching for triggers, etc. Data could be a precomputed table. The RIGOL makes a constant 20(?)MSh-stream.One point that I don't know what chip to use is the output drivers. Fast (20MHz minimum, rise-time adjustable would be an extra bonus) preferably short circuit-proof, can sink and source at least 20mA and with an variable supply voltage (up to 15V).
Nick
YADRO
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
I also thought about something similar but I did not think about I2C or SPI it really could help to program some values and send them and maybe listen to, the prop has enough to do that at some MHz!.
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
Some applications require even 24V. But simple patterns or even just a square wave would be enough for that.
I found the schematics of a HP 8116A, it does have (almost) suitable output-stages with 50MHz and 6ns (IIRC) rise-time. But I dind't have a closer look at it yet.
For the serial protocols (just as a clarification):
It simply sends the signals, does not receive. "The quick brown fox jumps over the lazy cat".
Nick
YADRO
if a high output level is needed, a simple Mosfet driver may be adequate if the frequency is not to high, like www.intersil.com/products/deviceinfo.asp?pn=HIP2100#longdesc. They are cheap and the high-side driver not even needs to have ground potential, what may be another advantage
ErNa
cmapspublic3.ihmc.us:80/servlet/SBReadResourceServlet?rid=1181572927203_421963583_5511&partName=htmltext
Hello Rest Of The World
Hello Debris
Install a propeller and blow them away
This doesn't look to bad. Diagrams end at 1MHz, but rise and fall time would allow almost 50MHz. OK, stressing the chip a bit behind specs maybe.
Thanks for the suggestion!
Nick
YADRO
For $30 you may want to consider the The Bus Pirate.
I've not seen anyone on this board mention it, but it seems to be pretty well known in the hardware hacker world. It can both send and receive, and you interact with it from a terminal emulator on your PC. There is also a GUI for Windows, OSX or linux in development.
It looks pretty useful. I've ordered one and am waiting for the next shipment in a couple of weeks.
From their website:
The ‘Bus Pirate’ is a universal bus interface that talks to most chips from a PC serial terminal, eliminating a ton of early prototyping effort when working with new or unknown chips. Many serial protocols are supported at 0-5.5volts, more can be added.
* 1-Wire
* I2C
* SPI
* JTAG
* Asynchronous serial
* MIDI
* PC keyboard
* HD44780 LCD
* 2- and 3-wire libraries with bitwise pin control
* Scriptable binary bitbang, 1-Wire, I2C, SPI, and UART modes
We added other stuff we need, like,
* 0-6volt measurement probe
* 1Hz-40MHz frequency measurement
* 1kHz - 4MHz pulse-width modulator, frequency generator
* On-board multi-voltage pull-up resistors
* On-board 3.3volt and 5volt power supplies with software reset
* Macros for common operations
* Bus traffic sniffers (SPI, I2C)
* A bootloader for easy firmware updates
* Transparent USB->serial mode
* 10Hz-1MHz low-speed logic analyzer
* Supported in AVRDude SVN
* Scriptable from Perl, Python, etc.
I have a Bus Pirate V2 (the V3 out now is supposedly hardware and software compatible). Haven't tried generating signatures with it yet. The Propeller would be an excellent candidate for a signature generator, parallel and serial, but you would likely in the end code in PASM for speed. Cog synchronization may be an issue. Remember PASM is typically four clocks per instruction which is 20MIPS per cog at 80MHz, without cog synchronization or access to HUB RAM which is slower. Plus starting cogs can be a bit slow (something like 100ms if memory serves).
I would really like to see something like the Bus Pirate done on an ATMEL AVR micro-controller instead of a PIC; typically 1 clock per instruction for AVR vs. four for PIC's, plus IMHO there is a full IDE for AVR's available for Windows unencumbered and not limited (AVR Studio plus WinAVR which is GCC-based). I could go on about AVR vs. PIC but this is probably not appropriate for this Propeller-Specific Forum.
It turns out Rigol makes the likes of DSO's for Agilent which re-brands them. I saw a YouTube video somewhere where someone exposed that Rigol is over-clocking ADI A/D converters to get higher sample rates - dicey approach in my opinion. Can't remember the YouTube link at the moment.
There are other ways to make fast signature generators. Fast DRAM externally refresh-clocked and programmed via a CPLD from an EEPROM, or something like this come to mind.
Bringing my post back to the propeller... I'm still waiting to see the release of the Prop-Scope from Parallax. The possibilities are almost endless and the device will (hopefully) be open and user-extensible. Hopefully the Prop-Scope will not rely on .NET framework.
Regards, David
Leon
Amateur radio callsign: G1HSM
Post Edited (Leon) : 11/15/2009 10:00:54 PM GMT
Are you using SFE's XMOS XTAG2 Debug Adapter?
BTW, all of SFE's XMOS breakout boards are sold out.
Did you order them all?.
JMH
Post Edited (James Michael Huselton) : 11/16/2009 3:16:28 AM GMT
As a clock for a 23K256 serial or faster parallel static RAM, what do you think of assigning one cog as output, and one or more cogs as
triggered inputs for a pattern generator/receiver?
I tire of waiting for the Prop2. XMOS is looking much more attractive lately, as is the 100 mhz ARM Cortex M3 LPC1700.
When the Prop2 is announced, the price is likely to be in line with these XMOS and ARM processors, so price is no reason to wait.
But the prop mental programming model is burned into my brain.
I just don't know - I must remember that this is supposed to be fun.
JMH
Post Edited (James Michael Huselton) : 11/16/2009 3:08:02 AM GMT
Hanno
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
All I've got to say is: wow
I have to remember that it isn't the chip, but the imagination of the programmer that uses the chip.
JMH
Post Edited (James Michael Huselton) : 11/16/2009 3:23:42 AM GMT
I am using the XTAG-2. One came with my XMOS XK-1 kit.
They only made a small batch of boards initially, probably to see how much interest there was in them. It looks like it could be a big seller for them. I think that most people buying them are already XMOS users, there has been a lot of discussion about them on the Xlinkers forum..
A DIL Propeller chip could be squeezed onto the prototyping area, the XMOS chip would make a nice peripheral device.
Leon
Post Edited (Leon) : 11/16/2009 3:35:18 AM GMT
OK, then the Prop II.
From an architectural POV, the Prop is a perfect match.
Nick
YADRO
