Bug in STRINGS library object
w8an
After having too much trouble with padded strings, I decided I better throw together a quick test program to see why I wasn't able to figure out the proper code for padding the left with spaces.
The version 1.3 Obex STRINGS object is not working.
This code:
produces this output:
As you can see, there is a glaring error in the PADL function.
..Steve
This code:
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
s : "Strings"
debug : "FullDuplexSerial"
PUB Start | paddedString
waitcnt(clkfreq * 5 + cnt) 'Start FullDuplexSerial
Debug.start(31, 30, 0, 57600)
Debug.Str(String("SERIAL Initializing...",13))
paddedString := s.StrPad(string("XYZ"),6,string(" "),s#PAD_RIGHT)
debug.Str(string("PADR -->"))
debug.Str(paddedString)
debug.Str(string("<-- size:"))
debug.Dec(strsize(paddedString))
debug.Str(string(13))
paddedString := s.StrPad(string("XYZ"),6,string(" "),s#PAD_LEFT)
debug.Str(string("PADL -->"))
repeat 'stop
SERIAL Initializing... PADR -->XYZ <-- size:6 PADL --> <-- size:3
..Steve
unless I'm totaly confused (that might be right), you cant use a local ("paddedString") for a string. Locals only store integers.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
In Spin "strings" are pointers (i.e. word-sized integer addresses) to zero-terminated byte arrays. paddedString is just such a beast, pointing to an array in the Strings object.
DEBUG.str(STR.StrPad(string("short"), 10, string("-_-"), STR#PAD_RIGHT)) 'Result: "short-_--_" DEBUG.str(STR.StrPad(string("short"), 10, string("-_-"), STR#PAD_LEFT)) 'Result: "-_--_"If anyone knows the author of the object, they might notify him so he can update the code.
Steve
My fault! I overlooked, that paddedString is assigned through s.StrPad.
Sorry for the fuzz.
Nick
YADRO
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Tom Talbot
New Market, MD, USA
If there are any requests as to what functionality people want in the object, please post and I will see what can be done.
Some of my objects:
Some of my objects:
