Questions about ROHS
william chan
I know this has been discussed before, but I can't seem to find the answers to my questions.
1. If I send a sample electronics product to Europe, do I need a ROHS certificate?
2. Can I make my own ROHS certificate for my own products?
3. Does every part and component of the product need to be certified?
4. If a shipment to Europe lacks a ROHS certificate, will it be returned or confiscated?
Thanks.
www.fd.com.my
www.mercedes.com.my
Thanks.
www.fd.com.my
www.mercedes.com.my
www.rohs.gov.uk/Docs/Links/RoHS%20Regs%20Guidance%20-%2021%20June%202006.pdf
You should also check the actual regulations.
Other EU countries will have similar requirements.
Certification will be required in a few months, I don't think that the details have been worked out yet. At present, you have to be able to show conformity only if it is required.
I was recently sent a non-RoHS ARM board made in India for review and there weren't any problems with it getting into the country. In theory, it could have been confiscated or returned. The supplier is redesigning the board to make it compliant.
You might also need to demonstrate CE conformity. That involves testing and could cost as much as $5,000.
Leon
Amateur radio callsign: G1HSM
Post Edited (Leon) : 11/14/2009 12:10:40 AM GMT
Parallax had a rocky change over to ROHS because all the 'experts' were pushing carrying two manufacturing lines - one compliant and one non-complaint. But in the end, double inventories and double production lines create untold certification hassles and the possibility that your staff sends the wrong product to a ROHS client. So Parallax, like just about the whole industry, has chosen to make everything ROHS compliant and no longer carry Pb inventory if at all possible. It is just the cheaper, easier way to manage your venture.
Still, if you are using jobbers out of China, many are not ROHS compliant and cannot qualify. You may have to shift to a jobber in the EU that can prove their manufacturing is 100% compliant in order to avoid certification hassles.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
If they say yes, then everything is no problem?
Does this also mean that I must let them procure all parts and components?
www.fd.com.my
www.mercedes.com.my
Leon
Post Edited (Leon) : 11/14/2009 2:08:05 PM GMT
So if a company says that they can do ROHS, but cannot supply certification - they may not really know how to do it.
1) PCB Is Silver, or Gold Plated. If not silver or gold then leaded tin is usually used. Also ask if they are ROHS Complian.
2) All parts you buy are ROHS Compliant. This is pretty easy these days since very few products contain lead anymore. Some things like lithium batteries are ROHS Excempt because there just is no alternative.
3) All solder you use is lead free. I through out all my 63/37 solder a year ago so I would not accidentally use it on any products.
By doing these 3 things I have made sure that all products I make are ROHS compliant. The life expectancy of ROHS compliant circuits is not as long as non ROHS compliant but lead is really not something you want to be working with and compliance is a must for world wide trade.
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
There is no official certification process for RoHS conformity, at present. It should be specified, of course, when dealing with a board supplier/assembler.
www.rohs.gov.uk/FAQs.aspx#25
Leon
Post Edited (Leon) : 11/14/2009 5:07:07 PM GMT
How do we get a ROHS certificate for these cards?
Does this mean that any prototype boards we make cannot be sent to europe for testing before volume production?
www.fd.com.my
www.mercedes.com.my
Where it will come to a head is if you want to sell your product regularly to an institution and in particular to a government agency in the EU, or if you sell thru a distributor. They will demand compliance with RoHS. Even at that level it depends mostly on voluntary compliance and it suffices for your company to state that it complies . And to do that honestly, you have to go down your bill of materials and check them off one by one. Every mainline distributor like Digikey, Mouser, Arrow, Avnet etc. and of course Parallax, list the RoHS status of the components they sell. Major PC board manufacturers give the option for lead free plating, and that is mostly the default option now. Same thing with assemblers. It is wise to keep a paper trail of all this stuff so that you can make a good case if someone asks for it, but that may never happen. CE is harder, and it is the EMC (Electromagnetic Compatibility) sections that are usually most problematic, although there are lots of special requirements for toys, medical devices etc. etc.. If your product contains a microprocessor, or high frequency or sensitive circuits, it will take special equipment to verify EMC compliance. It is an issue too if your product is a sub-assembly or component that will be used as a component in something else. The regulations in that area are tightening up.
Tracy Allen
www.emesystems.com
As I said previously, there is no such thing as RoHS certification! If the card is marked RoHS you might be OK, but it would be safer to buy it from a company like Digi-Key.
Prototype boards sent to the EU should be RoHS, of course.
Leon
Otherwise, no electronics product can be sold?
Should the CE and EMC certification be done by the UK distributor?
www.fd.com.my
www.mercedes.com.my
Leon
Leon
Post Edited (Leon) : 11/15/2009 6:19:14 PM GMT
But my enclosure is plastic.
Will it pass CE?
Do I need to line the inside of the enclosure with metal foils?
www.fd.com.my
www.mercedes.com.my
Post Edited (Leon) : 11/16/2009 12:27:40 AM GMT
