Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
RE: IMU Question — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
RE: IMU Question
schwiegjc
41
2009-11-12 20:17
edited 2009-11-13 00:47
in
Propeller 1
I am planning to try out the IMU Code example. I am planning to purchase the 5D0F Accelerometer/Gyro Sensor and 12Bit A/d chip. How do you actually display the results? The results seem to be in the Float form.
schwiegjc
41
2009-11-12 21:38
edited 2009-11-12 21:38
I found a FloatString Object that converts Float number to string. Will that work to display the results to a TV.
simonl
866
2009-11-13 00:47
If memory serves me correctly - yes, that'll do it
Cheers,
Simon
www.norfolkhelicopterclub.com
Announcement: To cut costs in the current economic climate, we have switched-off the light at the end of the tunnel.
Sign In
Register
to comment.
Cheers,
Simon
