Efficiently handling signed overflow in PASM? — Parallax Forums
ericballericball Posts: 774
edited 2009-11-12 01:35 in Propeller 1
I'm trying to calculate C = (A+B)/2 and C = (A-B)/2 in PASM, where A, B and C are 32 bit signed integers.· I'd like to gracefully and efficiently handle overflow of the intermediate result.· For unsigned addition I'd code it as:
mov c, a
add c, b   wc
rcr c, #1
But handling signed values and subtraction is making my head hurt.
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
  • AleAle Posts: 2,363
    edited 2009-11-11 20:37
    You should use adds and sar instead, and subs
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
  • AlsowolfmanAlsowolfman Posts: 65
    edited 2009-11-11 21:08
    i don't think 3 operations is possible. the simplest way i can figure out is C=(A-B)/2=(A/2)-(B/2). that should be free of head pain.
    mov c, a
    sar c, #1
    mov variable, b
    sar variable, #1
    subs c, variable
    overflow is avoided instead of handled.
    Post Edited (Alsowolfman) : 11/11/2009 9:15:07 PM GMT
  • BRBR Posts: 92
    edited 2009-11-11 21:42
    Would this work?:
          [b]mov[/b]   c,a
          [b]adds[/b]  c,b  [b]wc[/b]
    [b]if_nc[/b] [b]sar[/b]   c,#1
    edited 2009-11-11 22:01
    It will take four instructions:
    sum           [b]mov    [/b]   c,b            ' 7fff     ffff     0001     8001
                  [b]adds [/b]     c,a [b]wc[/b]         '+7fff    +ffff    +0001    +8001
                  [b]       [/b]                  '=fffe c  =ffff nc =0002 nc =0002 c
                  [b]sar    [/b]   c,#1           '=ffff    =ffff    =0001    =0001
            [b]if_c[/b]  [b]xor[/b]       c,_0x8000_0000 '=7fff    =ffff    =0001    =8001
    dif           [b]neg    [/b]   c,b
                  [b]sar    [/b]   c,#1
    _0x8000_0000  [b]long[/b]      $8000_0000
    It's easiest, thanks to the neg instruction, to treat both as sums. In this case overflow occurs iff two positive numbers sum to a negative or two negative numbers sum to a positive.
    Post Edited (Phil Pilgrim (PhiPi)) : 11/11/2009 10:17:33 PM GMT
  • ericballericball Posts: 774
    Thanks Phil, that's exactly what I was looking for. It handles the overflow (unlike a simple ADD+SAR) and doesn't lose precision (unlike SAR+ADD).
