Sharing SD SPI pins without unmounting
I have an SD card and an LCD screen (nokia 3310) that I want to have sharing the 3 SPI pins (DI\DO\CLK on the SD).
All works fine if I do this:
My problem is that I'll be playing wav files from the SD card and want the lcd to continue updating, but if I do this:
then the LCD does not initialise properly.
my understanding is that the CS pin is used to tell devices when to listen to the SPI bus, so it shouldn't matter what the LCD does when not accessing the SD card (in my actual code I am using mutex locks to ensure the SD and LCD are not clashing with each other).
For the SD I'm using fsrw24 (but rolling back to 2.3 or 1.6 makes no difference), the lcd code I have written myself, as far as I can see the issue is not because of anything I've done but I'm attaching the source code here just in case.
Currently the pinout is:
SD: DO = 10, Clk = 11, DI = 12, CS = 13
LCD: Reset = 8, CS = 9, DC = 10, DI = 11, Clk = 12
So far I can only think of three options:
sd.mount(10) sd.unmount lcd.Init lcd.str(String("Test"))
sd.mount(10) lcd.Init lcd.str(String("Test"))
- Alter fsrw somehow (seems like it would take too long to be worth the effort)
- Alter the wav code to unmount the SD card between reads (would require seeking back to the last file position, which could be too slow)
- Don't share any pins between the SD and LCD (looking like my favourite option because it was my original design so it's easy to go back to... would be nice to have a few more pins spare though)
See the TriBlade and ZiCog threads. I have solved the fsrw driver for Femto in the ZiCog/TriBlade femto driver. Lonesock/rokicki have added some extra code to disable the DO as well, but I don't have it working on TriBlade yet.
Mike: Yeah I realised that would be the issue, I thought I might get passed it since A) all the lines to the LCD are outputs (so it should be fine provided the SD cog leaves the lines as either inputs or low outputs, as all cog outputs are OR'd together) and
I could be wrong about B, if A is the only problem though (the low-level SD code not reverting the pins back to inputs\low) it should just be a matter of having it switch the pins on\off when it goes to\from it's idle state (this is of course my 'ideal simplistic world' thinking).
Cluso99: Thanks for that tip. I wonder, if Lonesock\rokicki have done code for it, does that mean pin sharing may work with the next·version of fsrw?
As with so many things this idea of sharing the pins sounded great (and simple) on paper, but is turning out to be more complicated in practicality.
32 pins seemed like a lot when I started this project! heh
FSRW will automatically reacquire the lines next time you ask "sdfat" to do something, so make sure the LCD is no longer using those lines before you read/write/open/close, etc.
You will need to uncomment the line immediately after "for Cluso99" in the release_DO section of the "mb_rawb_spi.spin", so it should read:
Jonathan
lonesock
Piranha are people too.
If I try to then make it low in the 'main' cog, it pulses (or at least the logic probe says it is [noparse][[/noparse]Sq. wave < 100kHz], I don't have an oscilloscope to see what it's really doing unfortunately).
I tried adding more calls to in8 in release_DO·in case it needed more clock cycles but it didn't seem to make any difference.
And as before if I call unmount first it all works fine.
sorry,
Jonathan
lonesock
Also, look in the Catalina code I wrote for the TriBladeProp - I also had to rewrite the spdi low level code to get it working, and make sure the XMM Kernel and the SD plugin correctly tristated the control lines in each case. The files to look at are:
Catalina_SD_Plugin_Input.spin
Catalina_XMM_Input.spin
both in Catalina\target\input - look for the "#ifdef TRIBLADEPROP" sections
Ross.
After calling release, DO and CLK are fine (tristated), CS is high (as it should be) and DI is still high.
At the moment I'm sharing DO and CLK pins with DI moved to its own pin and everything works fine.
I·should be able to make do this way,·can't see why DI isn't tristated though as release_DO clearly zeros dira, unless the card itself is doing something weird.
The test code I have now is:
sd.release is just a pass-through function that calls sdspi.release
logic probe shows DI pulsing after mount,·still pulsing·after release, then tristated after unmount.
I've also tried two different SD card brands (Transcend and Adata) and also tried using pins 2,3,5,6 just in case but got the same results.
Oh and the cards are microSD with SD adapters... shouldn't matter but thought I should give as much information as I can just in case.
As I said it's working now by giving DI its own pin, and whilst it would be a bit tidier to share the three SPI pins I'll pick a design that works over one that's tidy any day [noparse];)[/noparse]
I have some code that will auto-release after an inactivity timeout (currently 0.125 seconds). Once the timeout is exceeded, the release_DO code gets called repeatedly under the theory that it couldn't hurt. However, in my command handler if the last command was a reset, then it re-enables the output lines...then processes the fact that the new command is another release, and releases the lines. So, of the state of outa doesn't happen to match your pull-ups/downs, then the pins that don't match will be toggling!
This particular bug _should_ only happen 1/8th a second after you call release, though (I think, anyway).
Nice catch, and I'll try to fix this today...I just need to make sure my fix doesn't break anything else. (Hopefully this will make it work for Cluso as well.)
Jonathan
lonesock
Note: you will still need to uncomment the "mov dira,#0" line again.
Jonathan
lonesock
