PropBASIC Official Announcements thread
Bean
Since Bill has been touting his Propeller Basic.
I thought I would give him a little jab and post the progress of PropBASIC.
I have attached a document that shows the commands.
PropBASIC compile to straight PASM code. I have done a video driver (monochrome 64 characters per line, 24 lines).
In a future release we want to support LMM, but it will be an option. So you can generate straight PASM or LMM.
Next month we will be looking for some beta testers.· Ideal beta testers will have a propeller demo board, be familiar with PASM, and be familiar with SX/B (since PropBASIC is based on the SX/B compiler). Send me a PM if you are interested.
When it is released PropBASIC will be made available at no charge.
I have also attached a zip file with some demo programs already compiled.
SndMeter - Uses the Propeller demo board microphone and LEDs to make a sound meter.
Video - A simple 256x192 monochome graphics video display (NTSC)
Video2 - A 256x192 monochome text display. Unique in that the video driver cog also updates the bitmap with the text font.
Serial_to_NTSC - A buffered serial NTSC display. One cog receives serial data and puts the characters into a buffer. Another cog generates a 64 character per line by 24 lines text display. Very low memory overhead. Display array holds the HUB address of the font bitmap.
I will post more as it become available.
Bean.
Does that byte of memory hold "A", 65, $41 or %01000001 ?
Yes it does...
Post Edited (Bean (Hitt Consulting)) : 11/10/2009 2:55:55 PM GMT
Bean.
Yes it does...
It would be basically a text editor with a "compile" button. When the "compile" button is pressed it will save the file, run the compiler (.EXE), then start the Propeller IDE tool with the filename.
Bean
Yes it does...
The demo programs are in the first post as "demos.zip".
The compiler itself is not released yet.
Bean.
Yes it does...
For finalized .spin files, the original source PB could be placed in a block comment.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
The __PARAMx variables are NEVER used by PropBASIC code (like they are in SX/B). So these can be freely used in subroutines without having to save them in seperate variables. PropBASIC uses a seperate set of __TEMPx variables for it's use.
Note that TASKs do have their own variables (and SUBs) since TASK code runs in a seperate cog.
Bean.
Yes it does...
www.mikronauts.com Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
I have suggested to Bill that he take a look at CodeBlocks, the front end that Rich chose for the ICC V7 compiler.
Rich originally contacted me for the V7 rewrite in Visual Studio, but he chose the CodeBlocks compiler instead for the licensing freedom
and in-house support. In all, sounded like good business decisions to me.
Goodies like IntelliSense and compilation feedback are provided through a code feedback mechanism called Plugins.
The user gets a consistant look and feel when using products that use CodeBlocks.
Did I mention it is Open Source?
No need to re-invent the UI wheel...
JMH
Post Edited (James Michael Huselton) : 11/10/2009 8:40:54 PM GMT
It looks like CodeBlocks is for C++.
The PropBASIC compiler is written in Delphi.
Bean.
Yes it does...
Written in C++, but interfaces in script. At least have a look at the WIKI on documentation: wiki.codeblocks.org/index.php?title=User_documentation
I did review code that was necessary to write a Visual Studio interface. Maybe you have a better grasp of the legal concerns than I do.
p.s. - I loved Delphi when I was writing code in it - but it has been a few years since I last wrote any code in it.
JMH
Post Edited (James Michael Huselton) : 11/10/2009 10:30:50 PM GMT
I'm looking at some of my mbasic and sbasic programs and the ease with which they could be translated. Very easily I think. I've got a custom prop board with a big ram chip, sd card, vga, keyboard, 2 serial ports. Designed so that it can run CP/M in order to run various Basic programs in CP/M. The problem is that this needs 64k of memory in order to support a compiled basic program that takes 20k. But by running basic directly on the propeller, it means the memory overhead of an operating system may not be needed and hence it could all fit in 20k and then you don't need the external memory. Sweet!
This leads to a board design not dissimilar to the demo board. Consider a board with a couple of serial ports, vga, keyboard (?mouse) and sd card. All standard spin objects already available. Still leaves a number of pins free. Support chips might just be the eeprom and a max232. Faster, smaller, cheaper than the basic stamp. And running the same/similar language.
Re "If anyone is able to create a front-end for the compiler. I would appreciate it."
I've got a front end for the CP/M N8VEM board. It has evolved over a number of years and can do basic, assembler, C, one button compiles, shells out to other programs, a VT100 terminal, file transfers with xmodem and has a text editor that can do coloured text like vb.net/picaxe basic where keywords are highlighted. The catch is that it is in vb.net and I've had a few xp machines that won't run vb.net. So in terms of a front end, I'm wondering what is the best language to write it in. Mustn't be a bloatware language. Must run on a range of platforms. RobotBasic? Delphi? Whatever language Brad wrote the BST in? Something else?
I'm not familiar with Delphi - is it difficult to do a front end in this language?
www.smarthome.viviti.com/build
Compile it in lazarus and make it run on other platforms too.
If you always do what you always did, you always get what you always got.
Use Lazarus/Free pascal (Free Delphi clone) and "Write once, compile anywhere" (Windows, Linux, Mac OSX).
Lazarus Wiki
Lazarus en espa
The bst suite is written in Lazarus / Free Pascal. A night club in Perth, Western Australia has run it's entire music / lighting system for the last 10 years on systems written in Free Pascal. I might be a fan [noparse]:)[/noparse]
I was a Delphi programmer for years. I still have my 16 Bit Delphi 1 CD and Manuals here, but when (in 1996) I moved away from the Microsoft platform I found Free Pascal.
Initially I used to use Delphi in a Windows 95 VM to create binaries I could run under WINE. This worked quite well, but as Lazarus came up to speed I moved over to native development.
If PropBasic is written in Delphi and does not have a GUI, it would be _dead_ easy to compile it with FreePascal and have it actually run on non-microsoft platforms.
With Lazarus is a different story, because Lazarus was in diapers.
So I started bringing different types of aid:
- Translation into Spanish.
- Reporting bugs or repairing them.
- Building components.
And my last jobs were with Qt interface.
Lately I'm a bit withdrawn.
Do you use TFileListBox in BST?
No, I don't. Looks interesting though.
