reading voltage up to 330 volts with a microcontroller
I have a capacitor bank set up that charges up to 330 volts, i want to know what the voltage is at a certain point in time as the capacitors charge. is there such a device that will output a serial signal or pwm or something that i could read with either the propellor or basic stamp. this is for a charging circuit to charge the capacitors
http://forums.parallax.com/showthread.php?p=852035
330V -----\/\/\/\/-----/\/\/\/\-----\/\/\/\/----- Ground 1 Meg 10K Pot 5KThe wiper on the Pot gets connected to the input of the ADC and you charge up the capacitors to some voltage you know, whether it's 100V or 330V, then you measure the voltage at the Pot's wiper and adjust the Pot so that the wiper voltage is 1/100th of the voltage across the whole resistor string.
Remember that the resistors all have to be rated for the voltage involved. You may want to put a 5.1V Zener diode between the Pot wiper and ground to clamp that voltage in case of a failure of the 1 MegOhm resistor.
Either a Prop or Stamp can handle an ADC.
Just for security (as is usually done in such (HV) applications) I suggest you to replace the 1M resistor with two 500K or three 330K wired in series (just in case one fails)
· Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
