Do MOVI, MOVS, MOVD work on DIRA/OUTA?
Orthogonality would say that they should work...
If they do work, they would be a great alternative for some selective I/O!
I'd try it, but I am hip deep in the PropellerBasic code generator at the moment.
www.mikronauts.com Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
I was hoping that was the case! It will allow me (later) to make the code for my XMM much more readable, using MOVI to control latching the page address, and setting the read & write modes.
movs dira, #$F
movs outa, #$F
movd dira, #3
movd outa, #3
movd (and I assume movi also) does both a shift and place of the values, which could be useful for placing a byte-sized group of data values onto the IO pins.
