problem with LCDDEMO
Hello
I'm still new to the Propeller and Spin but am working through some of the Object Exchange Objects.
I am trying to use the LCDDEMO to drive a standard 4 X 20 with a Hitachi HD44780 driver chip.
I found the connection diagram in the driver documentation was incorrect (data lines and RS/E reversed) and once I had changed that I was able to get something displayed but only on lines 1 and 3. Looking in the HD44780 data sheet it seems that the memory locations for the characters on line 3 continue from line 1.
ie Line 1 ends at address 93 and line 3 begins at address 94. It seems that the INIT routine in the LCDDEMO is not configuring the display for 4 lines correctly but I can't figure out in the PUB INIT in the LCDDEMO to make the corrections. Does anyone else have any experience with this object.
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
Yes I went in and changed the INIT in the LCDDEMO object from 6 to 40 ($28) and all working.
I don't know if anyone else has had problems with this Object.
I had wired the d4-d7 pins using ascending Prop pins. This seemed to be the only driver that allowed me to do that. Now that you mention a problem with the schematic, I wonder if I'll be able to get this to work with the other drivers now. But no matter, that driver seems to do everything I need and is already configured for a 2 line display (just had to fix things a little for the 12 characters instead of the default of 16).
