Hydra Expansion Pin Out Definition
Timothy D. Swieter
I have the Hydra book, unfortunately that is at home while I travel so it can't help me confirm what I want to know. I am working on a board for the Hydra expansion and I wanted to verify the pin out and orientation of the expansion connector. I know the pin names such as
I/O_0 to I/O_7
NET_TX_DATA
NET_RX_CLK
RESn
SCK_CART
SDA_CART
33VCC
33VCC_LOOP
5VCC
5VCC_LOOP
USB_TXD
USB_RXD
GND
From the pictures of the expansion cards I gather that one side of the card has I/O_0 to I/O_7 as well as NET_TX_DATA and NET_RX_CLK. What I need confirmation on is the pin ordering on the backside of the card. I would guess the following
I/O_0 is directly in front of GND
I/O_1 is directly in front of USB_RXD
NET_RX_CLK is directly in front of RESn
is this correct? I think this makes sense based on this image because I can't imagine the lines doing a flip flop across the PCB to the J2 points (if RESn was behind I/O_0). This image was helping me, but if someone has the real thing and can verify I can continue with my design. www.parallax.com/desktopmodules/catalookstore/ImageViewer.aspx?link=Images/Prod/3/323/32361-L.jpg&desc=HYDRA+128K+Memory+Expansion+Card&PortalID=0&viewerid=-1&mid=-1
Thank you.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
I/O_0 to I/O_7
NET_TX_DATA
NET_RX_CLK
RESn
SCK_CART
SDA_CART
33VCC
33VCC_LOOP
5VCC
5VCC_LOOP
USB_TXD
USB_RXD
GND
Thank you.
www.tdswieter.com
Exp pin 2 - I/O_1
Exp pin 3 - I/O_2
Exp pin 4 - I/O_3
Exp pin 5 - I/O_4
Exp pin 6 - I/O_5
Exp pin 7 - I/O_6
Exp pin 8 - I/O_7
Exp pin 9 - NET_TX_DATA
Exp pin 10 - NET_RX_DATA
Exp pin 11 - RESn
Exp pin 12 - SCK_CART
Exp pin 13 - SDA_CART
Exp pin 14 - 33VCC
Exp pin 15 - 3VCC_LOOP
Exp pin 16 - 5VCC
Exp pin 17 - 5VCC_LOOP
Exp pin 18 - USB_TXD
Exp pin 19 - USB_RXD
Exp pin 20 - GND
Looking down from above, pin 1 is in the lower righthand corner, pin 10 is in the lower lefthand corner, pin 11 is in the upper lefthand corner, and pin 20 is in the upper righthand corner with the front of the expansion card facing downwards.
www.tdswieter.com
Why the 5v and 3v LOOP connections? These seem redundant to me.
If I read the specs correctly it looks like they are simply tied to their
3V and 5V counterparts. Why call them LOOPS at all?
Or do they serve another purpose I'm not seeing?
OBC
New to the Propeller?
www.tdswieter.com
My next challenge is figuring out why the keyboard and mouse connections are using two IO pins for each connection. (IE: the keyboard data line is taking up P13 and P14) I don't understand what's going on with the 3 resistors and 2N3904.
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
Andrew Williams
WBA Consulting
