Ultra-low cost LCD: Breakout boards to GadgetGanster! - Page 2 — Parallax Forums
2»
  • BeanBean Posts: 8,129
    edited 2009-11-05 17:33
    Rayman,
    Very cool....
    Can you control the symbols at the top ?
    Bean.
    Does that byte of memory hold "A", 65, $41 or %01000001 ?
    Yes it does...
  • RaymanRayman Posts: 15,968
    edited 2009-11-05 17:51
    Yep, each of the icons is individually controllable.· Four even have special commands devoted to them for some reason...
    What we really need now is a fast assembly driver to do 2 or 4 lines of·text·with graphics...
    Thinking about digging out some old Palm Pilot fonts...
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
  • pacmanpacman Posts: 327
    edited 2009-11-05 21:00
    I'm interested in 1 of each (1 with prop, 1 without).
    Have we got final pricing? How would I pay (paypal?)
    The future is in our hands.
    Which way to the future?
    edited 2009-11-05 22:56
    There's no Prop on these breakout boards... It's made to plug into the Propeller Platform, but you can use it with Protoboard or pretty much any setup you want...
    I'm thinking $15 for the breakout board + display.
    Keep in mind though that there's no real driver yet, just some test code...
    edited 2009-11-05 23:25
    Rayman said...
    Sounds fair. I'd still probably take 2. Postage would be to Australia, so don't forget to factor that into any calculation on $.
  • BradCBradC Posts: 2,601
    edited 2009-11-06 12:46
    pacman said...
    Rayman said...
    Pacman, if you want someone to share postage with, I'll take 4.
    If you always do what you always did, you always get what you always got.
    edited 2009-11-07 00:29
    I'm leaning toward sending these to Gadget Ganster too, so we can leverage the Prop Platform with it...
    edited 2009-11-13 00:39
    Just shipped the first 6 units to GadgetGangster.com to sell for me...
    Think we're looking at $15 each...
    Don't have a real driver yet, but Bean has volunteered to do it [noparse]:)[/noparse]
    But, I do have this demo code that is·a very basic driver...· It's shows the ROM Font on the screen.
    edited 2009-11-13 01:16
    Rayman,
    I will probably use an 8x8 font to generate a 15x4 character display.
    Have the ability to plot points and draw lines.
    I'll have to see what is possible when I get the display.
    $15 for a 122x32 graphic LCD sounds like a great price to me. You shouldn't have any trouble selling them at that price.
    Bean.
    Yes it does...
    edited 2009-11-18 15:02
    Rayman was kind enough to send me one of the modules and I have attach a propeller driver for it.
    For the text I used a 6x8 font to be able to get 20 characters across. It's a very readable font, even with it being so small.
    These are on sale at Gadget Gangster for only $9.99 right now http://www.gadgetgangster.com/find-a-project/56?projectnum=216
    That's a good price for a 120x32 graphic LCD with a backlight and alot of special icons too.
    Enjoy, and comments welcomed.
    Bean.
    Yes it does...
    edited 2009-11-18 23:40
    That was fast!
    Just tried it on my Propeller Platform, but it didn't work [noparse]:([/noparse]
    I wonder if it's this issue with the data pins labelled backwards on the breakout board?
    When plugged into the Prop Platform, the real D7 is on pin 16 and the real D0 is on Pin 23...
    edited 2009-11-18 23:41
    PS: Any chance I can talk you into putting an MIT license on this?
    edited 2009-11-19 00:12
    Rayman,
    Oh, I didn't put ANY copyright on it. But I can put the MIT license on it if it makes life easier for ya.
    I used the Propeller Profesional development board, but it should work on other pins ???
    I just connected the pin in order starting at pin 0.
    Tell me what you have each pin connected to, and I'll try it.
    Bean.
    Yes it does...
    edited 2009-11-19 00:55
    I just remembered that you can also plug it into the other side of the Prop Platform and their the data pins would be reversed:
    It works!
    Very nice!
    Here's the pins I'm using now and commented pins when on the other side:
    CON
      ' Change these pin numbers if you connect the LCD to different pins.
      PinRESn= 4'27  ' /Reset
      PinDC  = 5'26  ' Data /Command
      PinRW  = 6'25  ' Read /Write (can be just wired high, we never read back from the display)
      PinCSn = 7'24  ' Clock (data is read on falling edge)
      PinD0  = 8'23  ' data byte bits are reversed to make wiring look better!
      PinD7  = 15'16 ' Note:  Breakout board has D0..7 labels backwards!
    edited 2009-11-19 00:59
    Here's a photo showing it working on the bottom side of the Prop Platform...
    1496 x 1122 - 831K
