Programming Question.
While I am here another question.
Previously I was trying to create a checkboard pattern the computer monitor with dark and light tiles.
I which I was able to do by accident. Because it did not work as I thought.
I have added the debug to here, the working code is below.
The debug screen shows:
J start
1
-2
1
-2 and so on
If I start with j := 0 see code . I get columns not a checkerboard
and the debug shows:
J start
0
-1
0
-1 and so on
What is going on??? Why in the first example does j go from 1 to -2
when doing a !j and I get the checkerboard. And
Why does j do what I expect in the second example but I don't get the
checkerboard pattern, I get columns?? - especially since when I use j, I
am just checking if it is equal to 1??
Post Edited (reppig) : 11/5/2009 3:26:03 PM GMT
J start
1
-2
1
-2 and so on
J start
0
-1
0
-1 and so on
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
'512x384
tiles = gr#tiles
OBJ
gr : "vga graphics ASM"
debug : "FullDuplexSerial"
PUB MainLoop|i,j
gr.start
gr.pointcolor(1)
debug.start(31, 30, 0, 57600)
waitcnt(clkfreq * 5 + cnt)
j := 1 '<---------- SEE HERE IS THE PROBLEM
(if I change to 0 ----------------
debug.str(string("J start"))
debug.Tx(13)
debug.dec(j)
repeat i from 0 to tiles - 1 '16 columns x
12 rows = 192
if(i//16 == 0)
!j '<------------ HERE I USE IT
debug.Tx(13)
debug.dec(j)
if(j == 1) '<------------ HERE I USE IT
if(i//2 == 0)
gr.color(i,$00FF) 'wht on blk
else
gr.color(i,$FF00) 'blk on wht
else
if(i//2 == 0)
else
repeat
when you bit invert 0 you get $FFFFFFFF which is -1
now in your if statement you are checking if j == 1 which j will never be 1 when you start with j:=0 and then keep inverting
it will alternate between 0 and -1 and thus your if statements will always execute the ELSE section
When you set it to j:=1 and then inverting 1 gives you $FFFFFFFE which is -2 and the if statement will work correctly
since j will alternatively be 1 and not 1.
If you want to start with 0 then -1 etc just change the if statement from j == 1 to j==0··· or····· ·j==-1
But you are complicating the code too much ....I do not think you need the j at all....just do this....
(I do not have the "VGA graphics ASM" object so I could not try out your code)
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 '512x384 tiles = gr#tiles OBJ gr : "vga graphics ASM" debug : "FullDuplexSerial" PUB MainLoop|i,j gr.start gr.pointcolor(1) debug.start(31, 30, 0, 57600) waitcnt(clkfreq * 5 + cnt) repeat i from 0 to tiles - 1 '16 columns x 12 rows = 192 if(i//2 == 0) gr.color(i,$00FF) 'wht on blk else gr.color(i,$FF00) 'blk on wht repeatThis will cause the tiles to alternate white and black even from row to row since the 1st tile in each row will be the opposite of the
the tile above it in the previous row since you have an even number of columns.
Sam
