A Stamp is perfectly capable of controlling 25 LEDs and sensing the state of 25 switches. It can't do it directly by itself because it has only 16 I/O pins, but it can do what's called multiplexing which means that the LEDs and switches are connected in a 5 x 5 matrix and the Stamp works with 5 LEDs and 5 switches at a time and cycles rapidly through each set of 5 to handle the whole thing while using only 15 I/O pins.
Nuts and Volts Column #22 shows how to handle a 4 x 4 keypad when only one button would be pressed at a time. The circuitry and coding would be more complicated if you wanted to allow more than one button to be pressed at a time, but this is one example of how a button matrix might be handled.
www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol1/col/nv22.pdf
Post Edited (Mike Green) : 11/5/2009 6:03:45 PM GMT
