Screw specs in Mini F BB Servo
Hi -
Does anybody have the specifications for the screws that are used to hold the servo horns on the servo that comes with the Toddler? They appear to be 1/4", but I'm not sure of the diameter of the threads, or if there is a standard number for the screw. These screws were in so tightly from the factory that I had to press extraordinarily hard to get them out without stripping them...in the end, they did end up getting stripped enough that I can't screw them back in tightly enough for the horns to stay perfectly in place.
If anybody could help me I sure would appreciate it.
Shaun
Shaun
length is .295"
Diameter is .076"
Dave
Dave Andreae
Parallax Tech Support·
Thanks again for your help.
Dave
Dave Andreae
