I've broken Firefox - how can I un-break it?
I use Firefox as my browser of choice and on my windows XP box I've managed to break a small amount of the functionality.
When reading a forum and I click on "mark this forum read" I now get a full screen window saying marked as read (as opposed to the not broken system, which is just a small pop-up).
How do I get my small windows back ? - I've tried various combinations of shift/closing but all to no avail.
You help appreciated.
The future is in our hands.
Which way to the future?
Thanks for that - unfortunately it didn't fix the problem.
Anyone got any other stuff I should try?
The window is self closing after a second or two (most of the time). but I have tried the Restore button, Shift+Restore, Ctrl+Restore,etc etc (well you get the idea). I _think_ I've tried most combinations (with the exception of the one that works).. Heck I've even tried harsh language.....
It's not really a window - it's more another instance of Firefox..
So, anyone got some more ideas for me to try?
Thanks in advance
you haven't likely broken anything - it's probably just like Kwinn says --- it's a setting: window sizes are usually saved on close. Then the application (Firefox) just uses that size setting the next time around. You probably hit the middle button ("maximize")·and made it big before it auto-closed. You just need to set it back to small ("restore down")
1. mark forum read as normal
2. when the 'big window' pops up, quickly see if it has the three buttons in the top right corner, and click the middle one, then the red X --- this might be all you need. If not:
3. Do it again and this time see if you can grab the bottom right corner and resize it back, then close.
that doesn't work for computers - only for old, about to be abandoned cars [noparse]:)[/noparse])
Indeed this is what I've tried.
I have :- Resized and closed, restarted Firefox, Resized and closed whilst holding shift, Resized and closed whilst holding Ctrl, Resized and closed whilst holding shift and Ctrl, Closed Firefox whilst holding shift, grabbed windows edges and resized (and closed - with various combinations of shift/ctrl). Done all the above again with my tongue sticking out of my mouth at a jaunty angle, done all of the above with 'language' added to mix {I didn't realise it only worked on cars...I was sure it has worked on PC's before). Closed firefox, held shift when clicking "mark all read'. Closed via the "X", closed using file/exit.......
I honestly thought I has tried all the open/close/logoff/shutdown/resize options I could think of.
I'll go through them again tonight and hope that somewhere I get success - and then I will post my results.
I _really_ do appreciate you help on this. If someone does have another solution - {resize + Shift "X" + Stand on one foot + whilst facing East + speak in Gaelic all at the same time
pacman,
I fired up Firefox and tried maximizing the window in question. (You really have to be quick!) But the setting didn't stick: next time it came up small again. Thumbing through all the options, I did not see a setting that could cause it to pop up maximized, either.
Post Edited (Phil Pilgrim (PhiPi)) : 11/5/2009 7:16:51 AM GMT
Gland to see it isn't me.
But I _think_ I found a fix. Open your favourite forum, make the window the size you want the new pop-up to be. Shift + File/Exit.
Open Firefox again. Notice how small the window is... navigate to forum, then scroll about till you see the 'mark all read' link. Get ready. Click link - then quickly, use Shift 'X' to close the new pop-up. Open original (minimised) firefox back to full screen. Use Shift + file/Exit again.
Close and repeat. Keep fingers crossed....
Thanks heaps to all who offered suggestions.
PS: Phil - I'm actually more concerned by the fact that you car looks like it had a wooden rear bumper......
One of my biggest problems was with the distributor. No matter how much I tightened the holding screw, the gap would constantly go out of adjustment. My worst experience was during a drive from eastern Washington when the gap closed on the Mercer Island bridge in Seattle during rush hour on a rainy Friday evening. When the traffic helicopters report a "stalled vehicle blocking a lane of traffic", I was that guy. Fortunately, a cop pulled up behind me and, while he stood in the rain holding a flashlight, I popped the distributor cap and readjusted the points, thereby avoiding a wrecker call. (I always carried a timing light/dwell meter with me, just in case.) Ever since that wretched Pinto (may it's ugly corpse rust in peace) I've owned diesels: no more points or timing to adjust!
