What is the power plug thingy on the Propeller Demo Board called?
I'm making a printed circuit board that I wish to power with one of those simple 9 volt power supplies you can get at Radio Slack, one that has the same kind of connector that plugs into the Propeller Demo board. Problem is, I don't know what they're called. What I'm looking for is the same type as what is on the Propeller Demo board. To my eyes, it looks like it would be a female connector, but I know connector terminology can get a little weird sometimes, so I'm not even sure it would be classified as a female. If possible, I'd rather it be a part from Digikey, so if you happen to know a part number that you are certain will work, please let me know. If nothing else, I just need to know what to search for.
thanks,
Mark
thanks,
Mark
www.rapidonline.com/Cables-Connectors/Connectors-Mains-Power/DC-Power-Connectors/PCB-Mount-DC-power-sockets/80891
They are made by Switchcraft and should be available from Digi-Key or Mouser.
Leon
Amateur radio callsign: G1HSM
This one is pretty close to the one one the demo board.
http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=US&WT.z_homepage_link=hp_go_button&KeyWords=CP-202A-ND
It has a slot to fit in an enclosure.· Make sure to look at the data sheet.· That third solder tab (on the side)·is part of a switch so batteries can be disconnected when the power is connected.·
Duane
I'm glad I asked. I was looking for a female type plug and, ummmm, now I see it's considered a male. Hmmmm....
much appreciated!
Mark
Leon
Thanks Cluso.
The switching feature on this one and the one that Duane suggested is a feature I had never thought to look for. I'm happy y'all came to my rescue.
The CP-202A-ND is a bigger pin and is more common but usually requires slots. Make sure you wire the correct ground pins as one is switched. Since I dont use the switch I just wire both to ground.
Jim
What electronics need - MORE POWER!!!!!!!
however the 2.1 equiv. plug in the parts bin fits, but is twice the required length.
Works, but looks funny.
OBC
New to the Propeller?
