Spin code help
Hello Forum ,
I have little problem in how to start to make a delay to turn LED on .
I wrote this code
i will write the pseudo code what i want from this program to do:
repeat:- while ina[noparse][[/noparse]Y_INDEXPULSE]>0,turn LED on,wait 260micro, LED off: i't·done by the code above
··········- while ina[noparse][[/noparse]Y_INDEXPULSE]>0,wait·8ms to turn LED on,wait 260micro, LED off.
········· - while ina[noparse][[/noparse]Y_INDEXPULSE]>0,wait·6ms to turn LED on,wait 260micro, LED off.
········· - while ina[noparse][[/noparse]Y_INDEXPULSE]>0,wait·5ms to turn LED on,wait 260micro, LED off.
········· -while ina[noparse][[/noparse]Y_INDEXPULSE]>0,wait·4ms to turn LED on,wait 260micro, LED off.
········· -while ina[noparse][[/noparse]Y_INDEXPULSE]>0,wait·7 ms to turn LED on,wait 260micro, LED off.
how i can make it in intelligent way and nice in Spin ?
I hope that i describe good :-)
Thank you in advance
I wrote this code
PUB start|n
dira[noparse][[/noparse]LED_CONTROL]~~ 'set LED control port to output
WaitCnt(OneSecond*5 + Cnt)
repeat
repeat while ina[noparse][[/noparse]Y_INDEXPULSE]>0 ' wait for pulse
outa[noparse][[/noparse]LASER_CONTROL]~~ ' turn LED on
WaitCnt(MicroSecond * 260 + Cnt) ' LED on at first line of frame
outa[noparse][[/noparse]LED_CONTROL]~ ' turn LED off
Reason: The ina might be read just a short moment before the pulse arrives. Then the comparison and the next repeat statement will be executed before the next ina. Waitpeq and waitpne have an equivalent PASM instruction. So, an internal comparator constantly checks the ina-register. As long as the wait-condition is not true, the COG is in a halt state.
Is it ensured that the pulse of that pin ends before your switch on - wait - switch off sequence is finished? Otherwise your wait until might react twice on the same pulse.
For your variable wait-time:
1. use a counter variable to count from 0 to 5 - for example in a repeat loop.
2. define a DAT section "waittimes" for example, which contains 6 long values that you have to add to cnt in the waitcnt-statement
DAT
waittimes long 400, clkfreq*8/1000, clkfreq*6/1000, clkfreq*5/1000 ...
3. Use these values in the waitcnt like
waitcnt( long[noparse][[/noparse]@waittimes+counter] + cnt )
Hope that helps. If you have further problems, ask again.
PUB start | count dira[noparse][[/noparse]LED_CONTROL]~~ 'set LED control port to output WaitCnt( clkfreq + Cnt) [color=green] ' This makes it an endless loop, you have to decide if you want that [/color][color=green] repeat [/color][color=purple] ' here is the counter which simply loops through the timing list in the dat section. [/color][color=purple] ' As we have 6 values in the list, we loop from 0 to 5 [/color][color=purple] repeat count from 0 to 5 [/color][color=orange] ' this replaces your repeat until, which checks the input-pin. [/color][color=orange] ' As mentioned this only works fine if the pulse on Y_INDEXPULSE is shorter than the waittime and the [/color][color=orange] ' 260 microseconds. If not simply add a waitpne with the same parameters. That makes sure that the input [/color][color=orange] ' pin was low before waiting for high waitpeq( 1<<Y_INDEXPULSE, 1<<Y_INDEXPULSE, 0 ) [/color][color=red] ' here we wait for the time found in the table at position "count" waitcnt( long[noparse][[/noparse] @waittime+count ] + cnt ) [/color] outa[noparse][[/noparse]LED_CONTROL]~~ ' turn LED on WaitCnt(MicroSecond * 260 + Cnt) ' LED on at first line of frame outa[noparse][[/noparse]LED_CONTROL]~ ' turn LED off DAT MicroSecond long 80 waittime long 400 ' waittime + 0, this is close to the shortest time you can wait long 80_000_000 * 8 / 1000 ' waittime + 1 long 80_000_000 * 6 / 1000 ' waittime + 2 long 80_000_000 * 5 / 1000 ' waittime + 3 long 80_000_000 * 4 / 1000 ' .... long 80_000_000 * 7 / 1000 ' 80_000_000/1000 is equal to 1 ms if you run the prop with 80MHz. ' If not you have to change 80_000_000. The multiplication is done ' before because we don't want to loose digits due to integer-arithmeticsHave a nice day
PUB start dira[noparse][[/noparse]LED_CONTROL]~~ 'set LED control port to output WaitCnt( clkfreq + Cnt) if ina[noparse][[/noparse]Y_INDEXPULSE]>0 Repeat outa[noparse][[/noparse]LED_CONTROL]~~ ' turn LED on WaitCnt(MicroSecond * 260 + Cnt) ' LED on 260 microsecond outa[noparse][[/noparse]LED_CONTROL]~ ' turn LED off waitcnt( long[noparse][[/noparse]@waittime] + cnt ) ' wait 10 millisecond DAT MicroSecond long 80 waittime long 80_000_000 * 10 / 1_000 ' 80_000_000/1000 is equal to 1 mswhat can the problem from ?
thanks in advance.
please can someone tell me where the problem in the code mentioned above?
thanks
PUB start dira[noparse][[/noparse]LED_CONTROL]~~ 'set LED control port to output WaitCnt( clkfreq + Cnt) ' if does not wait until pin is high, it just checks. And if statement is true, it executes the correctly indented code [s][color=red]if ina[noparse][[/noparse]Y_INDEXPULSE]>0[/color][/s] [color=green]waitpeq( 1<<Y_INDEXPULSE, 1<<Y_INDEXPULSE, 0 )[/color] [color=#008000] ' indentation ... only code correctly indented is repeated[/color] repeat outa[noparse][[/noparse]LED_CONTROL]~~ ' turn LED on WaitCnt(MicroSecond * 260 + Cnt) ' LED on 260 microsecond outa[noparse][[/noparse]LED_CONTROL]~ ' turn LED off waitcnt( long[noparse][[/noparse]@waittime] + cnt ) ' wait 10 millisecond DAT MicroSecond long 80 waittime long 80_000_000 * 10 / 1_000 ' 80_000_000/1000 is equal to 1 msPlease note: Indentation is very important in SPIN. It replaces characters marking blocks as known in other programming languages. ( in C { 'do something } is a block·)
This will only wait for a pulse on Y_INDEXPULSE and then repeat forever. If you want it only to run if the input is high you need to change it a bit:
PUB start dira[noparse][[/noparse]LED_CONTROL]~~ 'set LED control port to output WaitCnt( clkfreq + Cnt) repeat [color=blue]waitpeq( 1<<Y_INDEXPULSE, 1<<Y_INDEXPULSE, 0 )[/color] repeat while ina[noparse][[/noparse]Y_INDEXPULSE] ' the >0 only eats up runtime. Every number that is not 0 will keep the loop running outa[noparse][[/noparse]LED_CONTROL]~~ ' turn LED on WaitCnt(MicroSecond * 260 + Cnt) ' LED on 260 microsecond outa[noparse][[/noparse]LED_CONTROL]~ ' turn LED off waitcnt( long[noparse][[/noparse]@waittime] + cnt ) ' wait 10 millisecond DAT MicroSecond long 80 waittime long 80_000_000 * 10 / 1_000 ' 80_000_000/1000 is equal to 1 msHey MagIO2, why not just
waitcnt( waittime + cnt ) ' wait 10 millisecond?
Also, earlier you suggested
but that won't work unless counter is a multiple of four. Just use
waitcnt( waittimes[noparse][[/noparse]counter] + cnt )
thanks for the comments.
I simply did not recheck that waitcnt-line, so it missed the evolution.
About the long: These things happen if you don't test the code before posting. I'm guilty for that.
