Prop II Timing/clocks
Will the Prop II have a more stable (lower error) oscillator? Accurate timing is essential to numerous capabilities. Maybe not a plug in atomic clock,
, but at least a temp controlled XTAL.
Swampie777
Swampie777
The Prop II will have a similar oscillator as the current Prop I. If you need timing to that sort of accuracy, you should use a temperature compensated external clock oscillator or temperature compensated crystal. The Prop I (and presumably the Prop II) will work just fine with an external clock source.
What external "more accurate" clock would you ( or other forum members) recommend?
Accurate time keeping or just frequency generation can get quite expensive.
A Fluke precision frequency reference will probably set you back a few grand.
Or how about an Agilent Technologies (www.agilient.com) Model number 5071A atomic clock with a long-term stability better than 1 x 10-14 price - $50,390
But as you have a Prop why not make a crystal oven. The Prop can control it's own crystals temperature.
There are many such projects described on the net.
My purpose is to increase the accuracy of measuring pulse widths over that which the Prop is capable now at a reasonable cost.
Swampie777
..Steve
Style and grace : Nil point
The Prop II will operate at a higher speed, so the resolution will be better, but the accuracy will still depend on the system clock source and you have the same sorts of choices for that.
