A few questions..
Hi everybody, I'm very new to the world of microcontrollers and well the entire electronic hardware as well and I'm really interested in playing around with the propeller chip because it seems like a great little piece of hardware that I could probably learn a lot from. I'm thinking of purchasing the Propeller Education Kit and have a few questions..
1. Would I be able to use This in place of the 32KB EEPROM chip that it comes with?
2. I'm also thinking of purchasing the SD card reading from Parallax, would I be able to integrate it into a breadboard without too much trouble?
3. Are there are PS/2/TV Video Out/maybe Ethernet interfaces out there that I would be able to implement into a breadboard without too much trouble?
4. Do you think that the P Education Kit is a good choice for me? I'm looking for something that I could learn a lot from in building electronics/electronic circuits and working with the propeller. I want to be able to eventually integrate external interfaces like PS/2, TV Video Out, Ethernet, etc.. The main reason I'm looking at the PEK is because it allows a lot of flexibility, and allows me to actually gain experience in building circuits and porgramming with the propeller. I want something that I will also be able to use to prototype designs/ideas, possibly to get printed on PCBs when I become more experienced.
Thanks for helping out a newbie
2) Yes. You just connect it to +3.3V, ground, and any set of 4 Prop I/O pins. When you initialize the SD card I/O driver, you specify which I/O pins are connected to which signals.
3) Yes. Parallax sells both phono jacks and PS/2 (DIN) jacks designed for use with a breadboard. The TV output requires 3 (or 4) resistors wired to I/O pins and a PS/2 interface requires 4 resistors and +5V from the regulator. Use the Demo Board's schematic for reference.
4) Sure. The PEK is a good starting point, particularly since you want the experience in building circuits.
2. Yes
3. Yes. Ethernet will require a module. PS2 & TV are just a handful of resistors and connectors and objects are already written.
4. I have had a look at the edu kit - good value. Suggest the USB version may be easier (the other is out of stock anyway) although you lose the propplug. If you go this way, get the PS2 p/n 28060 and TV p/n 28050 pcbs as well, since this is what you want to do.
If you can solder, the Propeller ProtoBoard with USB is another good cheap way to get started - also buy the connector kit as the connector is not so easy to get (you can buy from DigiKey). It includes the USB PropPlug on board. You may want to get the TV p/n 28050 also although you could wire on a socket (or cable) to the breadboard section plus 3 resistors.
Either way, you will enjoy the prop, and there is plenty of help here on the forum - just ask.
I knew only a tiny bit about electronics and very little about microprocessors when I started with the Prop Education Kit last year, and I found I was able to learn fairly quickly. From there, I've made my own printed circuit boards, photon counters, SD card data recorders, digital thermometer systems, digital pot controllers, VGA and TV displays, and I'm now working on a thermal gradient device using PWM for a biological application. But I must confess: I have leaned pretty heavily upon the generous gurus and geniuses that populate this forum. In fact I would say that the PE kit + forum community makes an incredibly powerful combination.
So, yes, grab your brain, get the kit, and jump right in. Here it's a pretty good swim without too much sinking.
And thanks ElectricAye for the encouragement and advice, it's nice to know somebody who went through what I am about to venture into
www.ladyada.net/make/ybox2/
www.deepdarc.com/ybox2
by the way, does anybody know on average how long it takes them to restock something like the PEK?
One last question though..
I'm looking for an Ethernet jack with built-in magnetics that I could put on a breadboard, does anybody know if this one (search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=553-1345-ND) would fit into a breadboard? If not, does anybody know of one? I do plan on adding Ethernet support to my propeller project eventually and would definitely prefer to stick with building my stuff on a breadboard. As a last resort I could just purchase the PropNIC, but I'd prefer to build my own circuit on a breadboard.
·· Just my two cents but I would order the t.v. and sd card from ucontrollers.com. They are almost plug and play. He will even solder the kits for you if you ask nicely. I have soldered 4 spinstudios with no problem but screwed up 2 tv cards, so I just asked him to solder the tv and sd cards for me.
·· When you get tired of the pek the paralax professional develpment board is great for trying out new components. Wait till it goes on sale, I bought mine for $89. I wouldn't pay $169 for it and I love the darn thing.
No seals, dogs, cats and·or· polar bears where harmed in the writing of this post. Countless millions of electrons gave up their lives for this message. I have no business relationship with ucontrollers and have not dealt with any other vendors from this site so I cannot comment on them.
Don
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
