ADC MCP3204 Demo Advanced Demo.bs2 and ADC MCP3204 Demo.bs2 Question
·I would like to use FOR and NEXT to run through four channels one at a time and only use these·two VAR over and over
How do I set this up
Can some give me an example of how you would do this
I could use this routine but
I can not select the order in which the channel are shown· This is the Problem that·I want to solve
·I know how control how many channel are shown·
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 10/31/2009 3:21:07 PM GMT
' File...... ADC MCP3204 demo.bs2
' Purpose... MCP3204 Demo
' Author.... Technical Support -- Parallax, Inc.
' E-mail.... [url=mailto:support@parallax.com]support@parallax.com[/url]
' Started... 8/20/09
' Updated... N/A
' {$STAMP BS2}
' {$PBASIC 2.5}
[color=red]' This code is only part of the hole routine this...>>> The part I need help with is how to set up the FOR NEXT...>>> I understand ' how to select the channel you BUT how do you SELECT ANY order which you want to see them in and you use the SAME VAR over again using ' this routine[/color]
[color=blue]result0 VAR Word ' Conversion Result CH0 mVolts0 VAR Word ' Result0 --> mVolts[/color]
DO LOW CS SHIFTOUT DataIn, Clock, MSBFIRST, [color=black][noparse][[/noparse] [color=red]%11000\5 [/color] ][/color] ' Select CH0, Single-Ended SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse] [color=red]result0\13[/color] ] ' Read ADC HIGH CS ' Disable ADC mVolts0 = result0 */ Cnts2Mv ' Convert To Millivolts LOW CS ' Enable ADC SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse] [color=red]%11001\5[/color] ] ' Select CH1, Single-Ended SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse] [color=red]result1\13[/color] ] ' Read ADC HIGH CS ' Disable ADC mVolts1 = result1 */ Cnts2Mv ' Convert To Millivolts LOW CS ' Enable ADC SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse][color=red] %11010\5[/color] ] ' Select CH2, Single-Ended SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse] [color=red]result2\13[/color] ] ' Read ADC HIGH CS ' Disable ADC mVolts2 = result2 */ Cnts2Mv ' Convert To Millivolts LOW CS ' Enable ADC SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse] [color=red] %11011\5[/color] ] ' Select CH3, Single-Ended SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse] [color=red]result3\13[/color] ] ' Read ADC HIGH CS ' Disable ADC mVolts3 = result3 */ Cnts2Mv ' Convert To Millivolts
' File...... ADC MCP3208 demo.bs2
' Purpose... MCP3208 Demo
' Updated... N/A
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
FOR channel = 0 TO 3
GOSUB GetADC
GOSUB DisplayADC
PAUSE 20
NEXT
LOOP
DEBUG CLS, "ADC CH 0 : ", CR, "Volts :", CR,
"ADC CH 1 : ", CR, "Volts :", CR,
"ADC CH 2 : ", CR, "Volts :", CR,
"ADC CH 3 : ", CR, "Volts :", CR
··Thanks for any·
Sam
- Rick
- Rick
Unless I misunderstood and what you really want is only two variables (one result and one mVolts}.
No you did not misunderstand· what I want to because that is what I want to
I did not think of doing it that way
Thanks for the Help
··Thanks for any·
Sam
·Do I have this right
I do not have a· ADC MCP3204 right now to test I have a MAX188 but I do not have it hook up right now
I just want to know if I have the right
Feed back need
DO Main: ADC = %11000 ' start with right ADC CH 0 ADC = ADC >> 1 ' shift ADC INPUTs to the Right [color=red]Not sure if this need << to the left or not[/color] DEBUG HOME, CRSRXY, 11, 0, DEC result, CLREOL, ' Displays voltages & digital value CRSRXY, 11, 1, DEC mVolts DIG 3, ' for all four channels LOW CS SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse]%11000\5 ] ' Select CH0, Single-Ended SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse]result\13] ' Read ADC HIGH CS ' Disable ADC mVolts = result */ Cnts2Mv ' Convert To Millivolts DEBUG CLS, "ADC CH 0 : ", CR, "Volts :", CR LOW CS ' Enable ADC SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse]%11001\5] ' Select CH1, Single-Ended SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse]result\13] ' Read ADC HIGH CS ' Disable ADC mVolts = result */ Cnts2Mv ' Convert To Millivolts DEBUG CLS, "ADC CH 1 : ", CR, "Volts :", CR LOW CS ' Enable ADC SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse]%11010\5] ' Select CH2, Single-Ended SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse]result\13] ' Read ADC HIGH CS ' Disable ADC mVolts = result */ Cnts2Mv ' Convert To Millivolts DEBUG CLS, "ADC CH 2 : ", CR, "Volts :", CR LOW CS ' Enable ADC SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse]%11011\5] ' Select CH3, Single-Ended SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse]result\13] ' Read ADC HIGH CS ' Disable ADC mVolts = result */ Cnts2Mv ' Convert To Millivolts DEBUG CLS, "ADC CH 3 : ", CR, "Volts :", CR PAUSE 100 LOOP UNTIL ( ADC = %11011) ' test for last INPUT CH 3▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 10/31/2009 8:17:20 PM GMT
