EEPROM Failure? Wierd Problem.
The problem is my USB Protoboard will only work if the usb cable from the computer is still plugged in during boot up.
About an hour ago I was ecstatic. I had just finished the first working version of my very first project. Everything is running fine, so I decide to download the program to the EEPROM and remove the USB Cable.
When I the switch on the power at first everything seems normal. The LCD screen has loaded the first page and gives me a menu, but when I press a button on the key pad nothing happens.
Has anyone ever had this problem before?
More INFO:
The program is loaded and verified in EEPROM.
If I remove the USB cable shortly after power up everything works fine. (?)
There are many devices in the project. So I thought I would first trouble shoot the keypad and LCD. I wrote a simple test program that displays a number for each key I press on the LCD. I then demonstrated that the program works on my PPDB( parallax professional development board). That is I loaded the program to EEPROM, unplug usb cable, powered off/on to success.
However, when I load the exact same program (to EEPROM) to the USB protoboard, unplug usb cable, power on--Nothing. Do the same thing with the cable in=success.
Any suggestions would be greatly appreciated.
Adam
More INFO:
Adam
There are a couple of things you didn't mention.
Are you powering the circuit from the same supply for testing both items?
This sounds like a power problem, not an EEPROM problem.
If you can cycle power after a download to the USB protoboard, with the USB cable plugged in, and the propeller work....then the EEPROM is working correctly. After power off the EEPROM has to supply the program to run.
EDIT.......sorry....are you saying if you boot the protoboard with the cable it works, even after the cable is unplugged???
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
Post Edited (James Long) : 10/30/2009 8:11:46 PM GMT
I think the eeprom is only being totally powered from the USB cable.
You may need to ohm out the eeprom connections on the protoboard. You may find a power/ground trace to the eeprom (from the regular power supply) to have a problem.
James L
James L
Partner/Designer
I have seen this happen a few times I do not have a PPDB is it the same I/O as your proto board? are you using the same size eeproms in both circuits? 256,512,1024?
http://forums.parallax.com/showthread.php?p=651731
http://forums.parallax.com/showthread.php?p=790298
http://forums.parallax.com/showthread.php?p=774972
That is interesting reading......thanks Phil. I had missed those threads in the past.
Thanks for adding the information.
James L
James L
Partner/Designer
Will not get around to correcting the problem unitl Monday but I am sure the 1K pull up or removing the Debug software will do it.
Thanks Again!
Adam
