Unofficial Halloween Contest 2009: Congrats to neoteric!
Oldbitcollector (Jeff)
Ok, It's Unofficial Contest time again...
Create a Halloween display which uses the Propeller (actively) by Midnight October 31st, 2009.
Projects must be posted to this thread by the deadline.
Bonus points awarded for videos of your project.
Myself and my boys will act as judges this year.
Prizes!
1 UPENE Protoboard Kit (USB Protoboard with PEstyled mini parts kit.)
1 Propeller DIP chip. This rare chip is highly sought. [noparse]:)[/noparse]
Worldwide involvement is invited...
Post your intention to participate in this thread.
and hey, you could always use the same project to enter the MAKE contest this year as well.
(Although, I can't imagine what you will do with $600 of PIC stuff. Sell it on Ebay?? [noparse]:)[/noparse]
OBC
New to the Propeller?
Post Edited (Oldbitcollector) : 11/3/2009 3:30:15 PM GMT
Prizes!
OBC
Yes, that's right my favorite time of the year is upon up again!
This year I wanted to do something different and this time I wanted to use the Propeller.
I am new to the Propeller and new to spin.
I came up with this idea for my Halloween costume this year, of the (MPIC), Mobile Propeller Interface Computer.
A costume of a computer nerd wearing a portable computer with keyboard and display small enough to attach on his arm with Velcro. I wanted it to display the number of pi constantly scrolling to say 500 or a 1000 places with some sort of graphics. The hardware is available for that, however I am pressed for time and don't think I will have the program completed by then.
So, here we go !
"I am willing to give it my best shot". I am a hardware guy.
Learning spin as fast as I can.
OBC
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
I'm assuming it's limited to single prop boards also?
No limits! The project must use a Propeller chip actively!
(In otherwords it can't be a simple costume decoration.)
OBC
I'll give it a shot anyways. Who knows? I may win and be able to sell that dip chip for a nice amount.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
If it's not Parallax then don't even bother.
I have changed my avatar so that I will no longer be confused with others who use generic avatars (and I'm more of a Prop head then a BS2 nut, anyway)
You can see the video here... the demo starts at 1 minute and 6 seconds:
Tim
I meant to bump that thread on the first, but somehow slipped.
It's an easy way to obtain a DIP40+
OBC
OBC
Want to·experiment with the SX or just put together a cool project?
SX Spinning light display·
Want cheap wholesale electronic parts?
Transistor parts wholesale
(It just can't be a Propeller chip stuck on your costume.)
OBC
The Geek Wearable Portable Computer.
Everybody has had a project gone wrong and I don't think I am the first !
My Halloween project that I have been working on sure did go wrong in the most important way.
After creating cables, battery connections, plugs and hacking some display programs for my big day-bue at the yearly Halloween party, my display cut's out after about 1 1/2 hours ?
You know, the worst nightmare you can have. After all that work and time you put into the project.
Well after some tinkering with power connection, no that is not the problem, then the display, no that is not the problem.
I turns out to be the video cable I bought at radio shack ! Bad luck I guess.
The only component I did not make !
It seems that all the walking around and the cable being a little stiff created a break in the cable about 1" behind the connector attached to the video out plug.
What bad luck, but there is a bright side.
I learned something about field testing that I have forgotten , Test Everything ! Even under stressful conditions.
I did not test the project by wearing it around or 3 to 4 hours with all the bending and walking around to view it's performance.
Good thing for test runs, and this is what it was.
I repaired the cable, cut off the end to make it shorter and soldered it on. Tested it on the bench.
Tonight or Thursday I will strap it on and take it for a spin.
Does the computer actually do something?
Display's sprites on the screen, mouse control's one sprite around the screen. 1 large LED at p0 blinking like a heartbeat.
At the time the pic's were taken all attempts to revive the screen were futile without a spare video cable.
Code was done in 12blocks. I added a PIR sensor. Except it is a foam pumpkin, and the "princess bride" carving was done in about six seconds on my CNC machine.
LED to pins 2,3,4 Flickers. PIR sensor to pin 5. I have the PIR hooked in the back. So you have to wave your hand in front of the pumpkin for it to see motion. When you do, the pumpkin flickers very quickly, as if responding to wind.
I hope others can make use of this for Halloween.
I included both the 12blocks code and the spin code for folks not using 12blocks. Have fun.
This (if it wins) will be good for Hanno and his 12Blocks program.
(Hey, this is my 800th post! Wehoo!!!)
A friend asked me for some help with this project. She wanted a Cylon themed Pumpkin. She pointed me toward a website with schematics using a 555 timer, a shift register and few diodes to form OR gates, and said "Can you build this for me?" I decided to throw a $8 Propeller at it and make my life much easier.
It's certainly overkill to use a 160 mhz, 8 core processor to blink 8 leds, but every project I do gets a Propeller nowadays.
Here's a video of the pumpkin - www.youtube.com/watch?v=0mA1CGTwXtI
couple of quick notes -
- The sound in the video is not from the Propeller
- one of the LEDs looks brighter than the others. In person you don't see that, just a matter of camera angle or some other effect going on there
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
Post Edited (parts-man73) : 10/29/2009 3:10:35 AM GMT
Great use of 12blocks! This is exactly the type of project ideal for 12blocks- use of a sensor or two to cause something to happen. I'm sure the blocks made it a "snap" to put together. I'm almost done adding support for multiple state machines and a "spin" block- that'll let you easily tackle much more complex projects as well.
Hanno
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
Micro
OBC
Hope you enjoy it as much as I did!!
OBC
Post Edited (microcontrolled) : 11/2/2009 9:54:20 PM GMT
Often code is better the second time around...
I agree with that completely, and its always a *lot* faster the second time around.
On the other hand, there is something to be said for regular backups. Not nice to have to learn the hard way however.
If you always do what you always did, you always get what you always got.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
