Input Question
Hello all,
use code below in my program.
IF modein = 1 THEN····························· 'latched switch, resets to 1 on power up
GOSUB Economy
ELSE
GOSUB Sport
ENDIF
I look at this input repeatedly & only want action on change of state,is there a way to do this.
thought maybe get scratchpad byte & current status but not sure how to do it
regards Adrian
GOSUB Economy
ELSE
GOSUB Sport
ENDIF
regards Adrian
modein PIN 0 ' alias for the input pin modein0 VAR BIT ' state variables for current and prior state modein1 VAR BIT modein1 = modein ' initialize prior state DO modein0 = modein ' read the pin IF modein1 ^ modein0 & modein1 THEN ' =1 iff pin changes low to high GOSUB Economy ELSE GOSUB Sport ENDIF modein1 = modein0 ' update the prior state LOOP Economy: DEBUG "1" : RETURN Sport: DEBUG "0" : RETURNThe logic statements involving XOR=^ and AND=& detect the change of state.
Tracy Allen
www.emesystems.com
Thanks for your reply,will giveit a go in my prog
Regards Adrian
tried your code & appears to work same as my original ??.
I could be i didn't explain what i need correctly.
my program runs the code shown as part of a main loop & each time it loops back if for example:·modein =1
it runs the sub routine if the next time loop runs if modein unchanged sub runs again (each sub drives·same digi-pot·with with different ramping rates so if sub repeats endlessly the solenoid driven from the pot cycles & this is showing up as a pressure pulse in solenoid hydraulic circuit. So really need sub not to run again until modein changes state.
How that is a bit clearer.
regards Adrian
is NOT part of your main loop. On the other hand the update statement,
does have to be in your main loop.
The logic function can be chosen to do what you want:
If you stilll have trouble with it, post your distilled code.
Tracy Allen
www.emesystems.com
