adding com ports?
I have bought the Propeller Education Kit with the PropStick USB, ive wired it all up and seems to be workign fine
*bright light when battery is connected
*dim light when connected to the computer
And when i connect the propeller chip to the computer the red and blue lights flash for a bit and the computer recognises it. But when i try and upload any program it scans COM ports 1 and 5 but doenst upload anything, it says "no propeller chip found". When i borrowed the same propeller chip from my friend it uploaded form COM port 4 i think, but now nothing seems to upload...
any Suggestions?
thanks
-D-
any Suggestions?
thanks
-D-
1) Inadequate power
2) Bad connection to the PC
3) USB I/O drivers not installed on PC or not functioning
4) Broken Propeller
Overwhelmingly, the problems that people have are #1, #2, and #3. The Propeller is a pretty robust chip and it's hard to break, particularly in the form of a PropStick.
Make sure things are properly connected on the PEK. Make sure you have a fresh battery ... they don't have much capacity. Make sure you have a current version of the Propeller Tool and the USB I/O drivers from FTDI (download a fresh copy from Parallax).
2) Bad connection to the PC: i dont see how this is possible as it worked with the other Propeller chip i had
3) USB I/O drivers not installed on PC or not functioning: same as above
4) Broken Propeller: i highly doubt that, seeing as i only bought it and put it in the protoblock.
Is there nothing you can do to add new ports?
When you press F7 on the propeller tool, it will progressively scan every available serial port on the machine excepting those marked as being bluetooth (as those make it go ugly). If it is not detecting your propeller then the problem most often lies at the propeller.
Does the machine recognise the serial port when you plug the propeller in? Can you open hyperterminal and make the little led on the board flash as you type?
lt's not particularly silly, is it?
Ok, so if you are seeing a little flashy light, *and* the propeller tool is not detecting things, then it appears the propeller is either not connected to the ftdi chip properly, *or* the propeller does not have power *or* the propeller is dead.
I guess there are other possibilities, but absent any more information I suspect it's one of the above.
for some bizszard reason. Thanks for all ur help
-D-
-D-
If all that checks out and still no-go I'd tear it all down and start from scratch.
It usually is.... I nearly smoked two regulators once because I missed the fact that I had used a resistor lead as a jumper on my breadboard and didn't remove it. I just so happened to connect VDD and VSS to the points it was shorting. Circuit no workie and bad smells in just seconds.
