has anyone written a spin program to show prop speed??? For Benchmarking ????
Hi guys I checked the Obex I have been over driving my prop chips but the only way I have been able to see performance gains is with my oscilloscope, has anyone written a utility program that would show the prop running any kind of benchmarks? I
would like to actually see if the prop chip is really speeding up visually.
I have been increasing the voltage to the prop chip and we have some left over liquid nitrogen from a project I was working on , so we have cranked up the volts pretty high but its not a lot of fun to just watch an oscilloscope
There was a thread a while back I can not find and I thought some of you guys had a program ??
When you increase the clock speed of the prop, your sample cycle time will decrease,
which will let you get shorter timing between samples, which means more samples per second.
So I could write a spin program that read the state of 20 pins all sequentially (using only 1 cog)
Then output the cycle time to a terminal, record the results.
Not only will the overall time it takes to read 20 pins decrease,
but the timing it takes between the reading of each pin will also decrease.
Benchmarks are nothing more than the relationship between time and completed cycles.
A PROPER benchmark would actually be a BURNIN program that activated as many features as possible on the prop and ran them constantly.
But generally, I agree with Mike.
Ross.
Not worth the effort. The PropII may be different in this regard but who knows.
But - apples and oranges anyway. What we really need is a workable code profiling tool to analyze where the most time is taken by inefficient algorithms.
Easiest way is to dedicate a COG and its two counters to profile the other 7 COGs.
Hanno, are you listening? ViewPort + Code Profiling. Prop I and II applicability. I'll write some base code for the profiler and the subroutine START and END timing capture.
Simple stuff, really, if you have written profiling code before - and I have written plenty for customers over the years. I may start a separate thread on this issue.
JMH
Post Edited (James Michael Huselton) : 10/29/2009 4:57:34 AM GMT
Comparing CPUs is of course more difficult especially when one has a completely different programming approach.
Increasing the voltage on the chip does not by itself improve performance and going to high will destroy your chip ... stay within spec.
Code profiling lets you see the results of badly-implemented algorithms and errors in judgement.
This but one of the tools experienced programmers use, as well you know.
Your implied suggestion of heartbeat code and other diagnostic code is very appropriate. We need all of the diagnostics we can handle.
JMH
I think profiling on microcontrollers is an interesting concept. I don't see the utility of it, but it's an interesting concept.
lt's not particularly silly, is it?
Given the huge variety of applications and possible implementations, Spin, PASM, C, one COG many COGS and all the trade offs people have to make, speed vs size vs complexity vs ease of use etc etc any benchmark numbers are pretty meaningless. Its very hard to find a benchmark X that will tell you if it is possible to implement function Y in the time limits required. You find out that Y is the benchmark you need[noparse]:)[/noparse]
Profiling can be very useful when you have written a huge pile of code for some application, perhaps in the simplest quickest way yo can, and then want to find out where optimizations may be beneficial. I can't see that it is so helpful on the scale of code we can fit in the Prop. Generally it's small enough to know your way round it all and see where the bottle necks are.
BradC: Why not? If you know your XTAL frequency then you can always measure time in seconds (or whatever) pretty accurately and then compare your Spin, C, PASM whatever execution time against it. No external measuring device required.
The context of the original post was benchmarking for the purpose of overclocking. So you are benchmarking code against varying clock speeds (which is pointless anyway as the execution cycle count won't vary in any case and you can just calculate it out).
Yes, you can use cnt values to compare relative code execution time, but you can't do that when you are varying the clock speed.
Having said that, I bet there are systems our there that add extra wait states for external RAM (say) when the clock speed is increased. Possibly leading to a decrease in performance for some small increases of clock.
As you say benchmarking for the purpose of over clocking is pointless, if it runs at all we already know how fast it will be from a "normal" speed test. The question is does it run at all and is it reliable ? At this point it would be good to have a program that exercises all features of the Prop in all manner of configurations so that we can be sure that all it's transistors are doing their thing correctly and that any extra heat stress does not kill it. Not exactly a "benchmark" perhaps a "benchtest"
I believe Sapieha has been working on this issue with his 120MHz tests.
Presumably Parallax has a suite of test codes that they have used to verify the Propeller logic. Perhaps they'd like to share that with the overclockers?
It is more true He talk on same program type as I some time ago - Test program for reliable functioning of Propeller with overckloking.
To one of my test I use 2 Propellers one that RUN in standard frequency and one that are overckloked - and in that configuration I have posiblity to test if overckloked Propeller Run correctly. And have posiblity to calculus some benchmarks for it (If overklocked Prop have stable frequency).
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
that would show a graphic on a display TV/VGA maybe a little bar graph like measuring bandwidth on a PC . To be honest I Really did not think it through just asked/typed out load. Like I said I had some Liquid Nitrogen leftover and I was just playing.
We ended up driving an old Pentium chip the big giant old ones with the gold pins back then it was just a Pentium 90 into the stratosphere its was amazing the speed you can get. I guess what led me to think about my prop chips is I have over clocked some of them but
I am just doing control applications, driving motors, looking at switches so there is really no reason to bother it was just a spur of the moment thing , BradC you are correct all of you are it was just a thought.
I don't know if any of you remember when the PC and Clones first came out at boot up it would display a little / character in the upper left hand corner that would toggle back and forth if you speed up the computer that little / slash would toggle faster and faster me and my friends became obsessed with over driving are PC's we had no decent software to speak of since we were all CPM nerds so there was really no point but before it all came to an end there would be 9 guys at a computer club meeting all standing around just booting are machines to show how fast that darn Slash would toggle back and forth It was like we were at a drag race LOL looking back its was shocking we ever got any chicks LOL
We used to keep track of the 16 or so Linux workstations for parallel build farms back in the early 90's. There was an X window widget that we started for each box and it would show the loads. Using "top", it was easy to see who was hogging all the CPU power. We would replace half the servers every time Intel came out with a new speed upgrade about every 6 months. We could use all the power available back then especially with 66MHz 486 boxes for doing builds.
I had no idea you worked with parallel CPU farms back in the 90's.
Great experience, wasn't it? I worked with clusters of RS6000's in the early 90's and switched to Beowulf clusters of PC's. My hat is off to you!
JMH
