2010 RF Design Contest - Propeller only?
I saw the advertisement for the contest and started reading through the rules and saw that the judging is based off of Propeller designs. It seems like Parallax should have stated that in the title or something. You have to use a transceiver which is ok but not stating that this is a Propeller only contest is a disappointment.
Is everything in the future just going to be assumed to be Propeller based?
Dave
Dave Andreae
Parallax Tech Support·
Clarification·would definitely seem·in order.
John R.
Click here to see my Nomad Build Log
I'll give you 75% for professionalism if you'll just fix the error rather than defend it·and move on.·
Duffer
Post Edited (Duffer) : 10/28/2009 6:50:07 PM GMT
May we have the 75% now? [noparse]:)[/noparse]
It's good to see willingness to support all your customers in contests and other events if possible.
Also, I think there is an error in the product documentation on the last page schematic. It should say
VCC = 3.3 V when VIN >"=" 3.3V (add the equal sign).
If that isn't an error, then it should say what VCC is when Vin <= 3.3V
Post Edited (SRLM) : 10/29/2009 1:38:49 AM GMT
The statement in the schematic is correct. VCC will only be equal to 3.3V if Vin is 3.4V or higher. So when you're powering from 5V the internal circuitry is running at 3.3V but when you switch to 3.3V there is some amount of drop-out on the regulator and VCC will only be 3.2V if I recall the drop-out voltage.· Whenever you have a regulator in a system, you have to account for drop-out when the input voltage equals the normal regulated voltage.
Chris Savage
Parallax Engineering
50 72 6F 6A 65 63 74 20 53 69 74 65
Post Edited (Chris Savage (Parallax)) : 10/29/2009 4:42:51 PM GMT
