BoeBot to something much bigger help needed
I have fiddled around building, dismantling, rebuilding a BoeBot til I am moderately comfortable with it.· Now what I wan to do is use the same basic robot electronics and programming but manage a pair of motors out of a Fisher Price Jeep that I salvaged?· The motors are 12VDC motors and should be prefect candidates for my project.· The motors can draw up to 100A at a complete stall so I know I am going to want to fuse the lines to them so they pop a fuse rather than all my electronics.· Beyond that, I am almost completely lost as to how to use the BoeBot electronics to manage these motors through some other group of components.· Can you guys help point me in the right direction?· Is an H-bridge something I should be looking at?·· Is my ignorance showing properly?
Jim
Jim
Is my ignorance showing properly? Yes but that will fade with time.
- Stephen
Thanks for the confirmation.· Now, ya got a good suggestion of what to start looking at H-bridges for the hobbiest that I wn't have to get a second mortgage to buy?
Jim
I am not sure if I would start with that big a motor - if something goes wrong there is a lot of power floating around - I have seen those motors smoke and a bot with that sort of power can hurt. I would get some experience with DC motors and H-Bridges with a small motor such as http://www.pololu.com/catalog/category/51 and a L293D h-bridge
I don't doubt that you are correct.· The issue is that I have these motors and don't have to go buy more and then have to figure out the gears and all of the other things from the get-go.· I can mount these under somthing and be on my way.· Over a period of time I am going to take the "from-scratch" approach but am trying to get a foothold without having to spend anymore than I have to.· Now, I realize that the cost of the H-bridges for the motors I have might end up being more thatn the cost of buying new motrs, with appropriate gearing, etc., and samll H-bridges.· I have to figure that out yet.
BTW, the moters are: http://www.mabuchi-motor.co.jp/cgi-bin/catalog/e_catalog.cgi?CAT_ID=rs_550pcvc·these guys.
Jim
http://www.robotshop.us/robotshop-rover-arduino-tank-kit-5.html
http://www.robotshop.us/dfrobot-4wd-arduino-mobile-platform-4.html
They are both fairly cheap - the 2nd is $41, you get a chassis and motors. The motors can be driven with a L293D which is $2-3 or a small controller.
I have used both: the 1st goes together easily, the 2nd comes put together. You get a chance to try H-Bridges etc without the worry of building a chassis that works.
Another option is to take your boe-bot and replace the servos with http://www.solarbotics.com/products/gm4/
This looks like a servo but is a normal DC motor that will need a H-bridge to control
I have used similar motors before - they tend to be slow but no worse than a servo will be.
Are you planning on use the stamp to control it? I haven't used a stamp and dont know if it can generate the 2 PWMs you need or whether you will need something like a PWMPAL
In any case, JimG, you need some very, very beefy H-bridges/motor controller. Will not come cheap. An integrated controller (i.e. one you can pulse like it was a servo, or that you can communicate with serially) will add even more to the cost. If it were me, I would probably pick up a pair of high-current full H-bridges on a board and set up something like an SX to run them (via PWM). Even so, a board in the current range will probably run $150-$250 -- and you need two of them.
Of course, if speed control is not an issue, heavy-duty relays (salvaged?) might do, but even so, 100A is hefty and you'd still need driver circuits (or something like a darlington array IC) to trigger the relays from a micro like a Stamp.
That said, you could purchase your own components and roll-your-own H-bridges, but given the requirements it might be better to purchase made units -- you'll save huge amounts of time and frustration. THEN, for your next project, build your own given that you'll know what they are and how to use them
Post Edited (Prettybird) : 10/27/2009 1:46:47 PM GMT
Jim
You can generalte PWM with a Basic STAMP.· Take a look at the PULSOUT command.
Jim, K6JMG
I am NOT challenging you, I just am ignorant. Help me understand, please. If I issue to PULSOUT staments on right after the other are you saying that there is a timing issue because they are not issued at the same moment in time? If that is the case how is this done with any other chip short of multithreading?
Jim
PWM for H-bridges and the like are much much higher frequency, and are duty cycle based, so the PWM really needs to be very fast, very tight, consistent. Even with some clever coding to simulate it, the Stamp isn't fast enough to do this reliably, nor would there be any time left over for other tasks. On a fast micro with deterministic timing (say an SX or PIC or AVR using interrupts or a Prop with multiple cogs), the PWM state (high/low) and duty lengths of the output pins can be tightly maintained while there is still plenty of time in the mainline program for other tasks -- like reading sensors, updating servo/motor values, outputting to displays, etc.
For example, technically this code would drive two full H-bridges in one direction then the other.
idx VAR Word OUTA = %0000 DIRA = %1111 Forward_Half_Speed: FOR idx = 0 TO 1000 OUTA = %0101 OUTA = %0000 NEXT Forward_Full_Speed: FOR idx = 0 TO 1000 OUTA = %0101 OUTA = %0101 ' to even try to get consistent timing NEXT Left_Forward_Right_Backward_Half_Speed: FOR idx = 0 TO 1000 OUTA = %1001 OUTA = %0000 NEXTThe problem is that times will not be consistent (the loop on the "next" will take a bit more time then writing the two values to the output pins). And slow. And 1000 *what* in the loop? The loop is not 1000 *anything* such as milliseconds, or clock cycles -- it's just 1000 of however long it takes the particular Stamp to execute one iteration of the loop. Lastly, you would have no time between changing/updating outputs to do other things.
For the novice user, and when $$ is less of an issue, there are standalone PWM modules like the PWMPal, and other pre-programmed chips. Otherwise -- as I and many have done -- you can program a separate micro to be your own home-brew motor controller, that accepts commands from the host (a Stamp or other micro) via serial or the like, and outputs/updates things like PWM, encoder counts, etc.
Post Edited (Zoot) : 11/4/2009 11:27:04 PM GMT
Jim, K6JMG
www.spinochio.com
I was thinking of just using some big can transistors behind my prop control board .. Wouldnt this work?
JimG -- for what it's worth, if you built the driver portion, the sample code above, or something similar, would certainly suffice for testing the hardware and seeing if it drives your motors, gets hot, burns, etc
Just FYI, I have set tehbig motors aside in favor of a couple of small motors salvaged from printers. I have to other robotic motors with gear trains and wheels ont eh way. The stobe-bought jobs draw about 1A at stall. I am driving the with a L298 chip. I want to drive th eL298 with the STAMP but am starting to see that that isn't going to work.
Jim, K6JMG
www.spinochio.com
I'm doing it with just PULSOUT commands but will try the code you werer kind enough to post tomorrow. Just so you know, I am setting the motor pins high or low as is appropriate and pulsing the enable pin on the L298.
Jim, K6JMG
www.spinochio.com
00 = off
01 = forward (or reverse depending on how motor is wired)
10 = reverse
So by switching rapidly between 01 and 00, for example, you get a speed.
Pin0 => 1A ' motor 1
Pin1 => 2A ' motor 1
Pin2 => 3A ' motor 2
Pin3 => 4A ' motor 2
You could wire up a switch to both enable pins which would give you a "kill" switch that could be tiny as it doesn't have to handle the actual motor current.
Setting pins for direction and then sending PWM to enable is nice, but takes an extra pin for each motor (6 total instead of 4). Over-the-counter motor driver modules often have some NAND logic glue chips that handle setting the two direction pins with one master input pin (direction=0 or direction=1) and a separate master input pin for PWM (speed). This saves the host from needing more pins and absolutely prevents a programming error from driving both sides of the H-bridge high at the same time (not really a problem in an intergrated IC like the L29X series, which shuts down upon such an input error).
I'm also upsizing from Boebot/Scribbler, but in a more manageable step. I found small 24V, 1A stall gearmotors that I'll be operating at 12V, 500 mA stall. I want a slow & careful platform for indoor navigation. Lots of choices for CHEAP motor control with these low-power motors, anything from a $30 dual motor controller to bang-bang relays. And my battery is a cheap gel cell, brand new for $14. Something to consider, based on your needs.
I started a Robotics thread under $10 gearmotor. My chassis is complete, and should be driveable in a few days. I'll post some pics & vids when I can.
You go!!
As I mentioned in this thread somewhere, I have put the big motors on the shelf for the time being and ordered a couple of 1A motors with gear assemblies and wheels to play with. The issue remains as to how to drive the L298 which in turn drives the motors. I have some suggestions that I am following up on but am always open to alternate ideas. I may end up (sacrilege) using a BaasicATOM instead of the STAMP.
Jim, K6JMG
www.spinochio.com
Jim, K6JMG
www.spinochio.com
With 8 cores of processing power and those new 6.25 MHz crystals you'd be hard pressed to have speed issues!
RoboGeek
BS2: $49
SX48 Protoboard: $10
Propeller Protoboard: Priceless
www.apple.com
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.jameco.com
PG
I also use my Propteus board (link in sig) for my robots - I designed it for easy prototyping and 12 servo's.
www.mikronauts.com Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
