Input Registers for 32-bit Ports A
Hello Forum ,
in the manual of the propeller , they wrote :
Input Registers for 32-bit Ports A, INA:
a low (0) bit indicates the corresponding I/O pin senses ground, and a
high (1) bit indicates the corresponding I/O pin senses VDD (3.3 volts).
I have a 3.4volts, this value can distroy the propeller demo board ?or it's better i will change my schema to have exactly 3.3volts? and to don't risk with it
Thank you in advance and have a nice day ,
Masha
Masha
Leon
Amateur radio callsign: G1HSM
But during hardware and software development/testing it's always a good idea to have a series resistor, as it protects your propeller in case you accidently set the dira to output on a pin that's connected to a device already driving the line.
Also inputs can swing higher than Vdd by up to 0.3V so 3.4V is safe and doesn't "need" current limit resistors although it is a good idea to include them as has been mentioned.
Recommended operating voltage for the Propeller is 3.3V with a safe use to 3.6V. The Prop may survive voltages higher than these but there are no guarantees for how long etc. I have used 3.6V before for interfacing outputs to standard 5V logic.
*Peter*
