XBees in API Mode... Help
Evening,
OK, I have had these XBees for 6months now, and everytime I try to get them working, they don't and I get upset with them (repeat weekly). SO, I need some help apparently.
I have a end-node, which I am simply trying to send some data to the coordinator.
I am a pro now with X-CTU, and I can get them working fine in AT mode. The key is that I want to get them working in API mode... which I can't seem to do.
Both units are on the same PAN (the PAN LED is steady, the end-node is blinking twice as fast as the coordinator, and the end-node receives the DL address, etc from the coordinator)
I have a logic analyzer and a whole slew of analysis tools, and I can't figure out why they're not working because everything seems fine, so maybe I am missing something simple...
For example:
I have built the same exact packet as on page 89 of the XBee manual (http://ftp1.digi.com/support/documentation/90000976_C.pdf), and I have confirmed this with my logic analyzer (see attachment). The baud rates are the same between what is sent to the XBee and the XBee's config (9600).
Here's the PUB of my .spin file which sends the packet:
note: destAddress[noparse][[/noparse]n] is all $00 bytes, as I am trying to send to the coordinator
I have noticed that the XBee that is transmitting (the end-node) does not output anything to show and error, nor confirmation that the data was sent (I thought it was supposed to when AP=1?)...
SO, can anyone share their thoughts, or perhaps some code that works and explain your setup?
- Josh
For example:
PUB SendtoXBee | j, k, a_byte, csum
j := 0
TXpacket[noparse][[/noparse]j++] := $7E 'Start delimiter
TXpacket[noparse][[/noparse]j++] := $00 'Length byte 1
TXpacket[noparse][[/noparse]j++] := $16 'Length byte 2
TXpacket[noparse][[/noparse]j++] := $10 'API identifier
TXpacket[noparse][[/noparse]j++] := $01 'API frame ID
TXpacket[noparse][[/noparse]j++] := destAddress[noparse][[/noparse]0]
TXpacket[noparse][[/noparse]j++] := destAddress[noparse][[/noparse]6]
TXpacket[noparse][[/noparse]j++] := destAddress[noparse][[/noparse]7]
TXpacket[noparse][[/noparse]j++] := $FF '16-bit address of the destination device
TXpacket[noparse][[/noparse]j++] := $FE '--> 0xFFFE is the address in unknown
TXpacket[noparse][[/noparse]j++] := $00 'Broadcast hops - 0:use maximum
TXpacket[noparse][[/noparse]j++] := $00 'Options
TXpacket[noparse][[/noparse]j++] := $54
TXpacket[noparse][[/noparse]j++] := $78
TXpacket[noparse][[/noparse]j++] := $44
TXpacket[noparse][[/noparse]j++] := $61
TXpacket[noparse][[/noparse]j++] := $74
TXpacket[noparse][[/noparse]j++] := $30
TXpacket[noparse][[/noparse]j++] := $41
TXpacket[noparse][[/noparse]j++] := $13 'Checksum
repeat a_byte from 0 to 25
SER.dec(CONSOLE,a_byte)
SER.tx(XBEE,TXpacket[noparse][[/noparse]a_byte])
SER.txflush(XBEE)
- Josh
I've gotten the XBees working in both the YBox2 (propeller) and my PropSense boards (propeller).
I'm a Logic Analyzer user as well. (I work on one of the largescale logic analyzer teams)
Love the analyzer screen shot. I may have to get one of these smaller ones...
Turns out that life is really bad when the XBee devices are allowed to sleep.
You don't seem to mention it so I thought I would... they going to sleep on you?
I monitor XBee pins 13 and 15 to determine state. 13 is off when sleeping...
I was chasing problems (my tail?) for weeks until I figured this sleep thing out.
Stephen
Related Threads: http://forums.parallax.com/showthread.php?p=825391
(links to pics of my new boards, too)
Any other ideas?
On the same topic, does the XBee need any other connections other than power and the serial lines to the Prop for API mode?
Or, when in API mode, does the XBee need to be configured by the Prop somehow before it is ready to send? Or can you simply start sending transmission packets to it, like I have been?
API mode was given up on for XBEE 1 (Motorola part). API and simple passthru okay for the Cypress parts (XBEE 2).
I struggled for five years until an engineer gave the straight info.
JMH
Post Edited (James Michael Huselton) : 10/25/2009 7:53:26 PM GMT
I believe their power output is 2mW, and they have the wire antennas.
There are a few sticklers with using api mode, at least when using the xtends, which are similar.
There can be limitations that are not clarified. You cannot send an api packet larger than 256 bytes with the xtend in repeater mode, and also you cannot send two large api packets back to back , as the second one will not go through unless you give it time to process the first one. This is not stated in the manual, I had to find it out the hard way.
Api mode is a little more work, but it is so superior that it is worth the effort, at least if you are doing addressing on the fly, and wish to know the rssi easily.
I forgot that when I changed the destAddress from the example to the coordinator, that the csum will change. I have a pretty good idea how to calculate the csum, but the documentation says to only keep the lower 8-bits of the addition... and I don't know how to do that.
Something like: csum := $FF - [noparse][[/noparse]Summation of (4th byte) to (packet length, not including csum byte)] , right? But what do I do about only keeping the "lower 8-bits"?
I am only sending a small 25 byte packet, and I know the benefits of API, which is why I want to use it... but it just doesn't work, so I would like some code or some details from someone who got theirs working.
I haven't found much for information anywhere, and the whole key to the abilities of the XBee units is the API mode... so if anyone has any information, please share - this could finally be the location on this forum for how to get API mode working with the XBees.
This is not that difficult to find if you are doing it right. Remember that over the air the packets are identical. API mode only changes the way to send and receive packets from the UART. You can use one on regular mode to debug your sending and receiving. A serial port spy is invaluable to debug this also. http://www.serial-port-monitor.com/
checksum is figured from 3rd byte to last before checksum.
I had to change from brackets to ( ) so it is not true c code. Otherwise the forum wouldn't print it right. I think you can get the gist though.
char sendAPI(char *TP,short qt, char ID,unsigned int DT,char option)//Adds checksum { Disable_control_ir(); int a,QT; QT=qt+5; unsigned char checksum=0; while(!U1STAbits.TRMT);//make sure tx buffer is clear txpointer=&localtx[noparse][[/noparse]0];//set pointers while(DigiX.tx);//wait for last transmission to clear mU1TXClearIntFlag();//clear interrrupt localtx(0)=0x7E;//start delimiter localtx(1)=QT>>8;//high byte length localtx(2)=QT&0xFF;//low byte length localtx(3)=0x01;//API identifier localtx(4)=ID;//Frame ID localtx(5)=DT>>8;//DT high byte localtx(6)=DT&0xFF;//DT low byte localtx(7)=option;//Option for (a=0;a<qt;a++) { localtx(a+8)=TP(a);//copy buffer checksum+=(unsigned char)TP[noparse][[/noparse]a];//figure checksum } // checksum=checksum+localtx([noparse][[/noparse]7)+localtx(6) +localtx(5) +localtx(4) +localtx(3); checksum=0xFF-checksum; localtx(QT+3)=checksum; txcnt=QT+4; txpcnt=0;//set pointer to next byte in series for(a=0;a<4;a++){//repeat four times to fill buffer if(txcnt>0){//only if count is not reached U1TXREG=*(txpointer+txpcnt); txpcnt++; txcnt--; } } txintenable = 1;//enable interrupt G_rxtx=1;//led R_rxtx=1;//led DigiX.tx = 1;//flag send Enable_control_ir(); }chksum := $00 repeat k from 3 to (j-1) chksum := chksum + TXpacket[noparse][[/noparse]k] chksum := $FF - chksum TXpacket[noparse][[/noparse]j++] := chksum 'ChecksumThat's how I did it - the 'chksum' is a VAR as 'byte chksum '
I am now sending data reliably, and a whole range of possibilities just opened up.
Thanks all for your help.
- Josh
