Electronic microscope or macro camera for SMT inspection
I need a system to put circuit boards on a large flat screen for inspection. Using magnifying glasses is a hassle. Using typical security cams are fine if you are always at a fixed distance from the subject, but they have very shallow depth of field. I am looking for some method the blow up board on a TV screen without the focus hassles. Any suggestions?
- Stephen
There are microscopes (even on Ebay), fitted with cameras which are connected to TV's.
They are not cheap, but are meant to do what you are looking to do.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
It works really well for looking at circuit boards. It was made for children
but it seems to have good quality. I also have a really
cheap USB webcam (640x480) that I got on ebay for 12.00 and since it
has an adjustable focus ring it also works pretty well to look at boards.
The webcam is easy to use since it has a ring of 6 white LEDs on the front
for illumination.
EDIT:
I have an old 3.2 megapixel canon camera that I don't use much any more.
It has video output for hooking to a tv and I just tried using it to look at boards.
Placing it on a miniature tripod I got at Dollar Tree for 1.00 made it really easy
to focus on a circuit board using the macro setting and the zoom...it's actually
easier to use than the other 2 cameras. If you have an older camera gathering
dust you should try it
"Where am I? Where am I going? Why am I in a handbasket?"
Post Edited (HollyMinkowski) : 10/24/2009 11:37:45 PM GMT
I have one of the expensive stereo microscopes with a camera. Even at the lowest magnification, you still need to focus on anything 3-D. You might be able to get the circuit board in focus, and see the solder joints, and even the top of surface mount resistors. Much more than that might be starting to get a little fuzzy.
More light, and a lower f-stop help some, if you have a camera that works that way, but other than at very low magnifications, by the time you get enough light, you start to loose contrast, and things get hard to see, especially shiny stuff, like leads and solder
John R.
Click here to see my Nomad Build Log
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
in the center and placing it on the lens. The pinhole might work to increase the F stop
value and give a huge depth of field. You might not even have to worry about
focusing the lens any more. You will need more light of course...white LEDs should work
well if you affix them on the camera some way.
I have some tiny ccd cameras and I tried using a pinhole in front of the sensor and the
result was absolutely razor sharp images in full daylight... from infinity to as close as
you could get an object to the camera...I cut out a small piece of that sticky metallic foil tape
and stuck it onto the lens holder of the cam and indented it with a fingertip so I could spot the
center point easily and then I just stuck a needle through to make the pinhole.
I can't remember if it is the QX3 or the QX5, but I think it is the QX3. It does a decent job for a cheap "toy".
I could probably post some PCB pictures from it, but it's not expensive. Just give it a try.
Bean.
Does that byte of memory hold "A", 65, $41 or %01000001 ?
Yes it does...
All you need is a PC and your imagination! Explore microscopic worlds at 10, 60, and 200 times their original size! The Digital Blue QX5 Computer Microscope can capture and record images and video on most PC computers. Experiment with the microscope and the PC.
# Resolution: 640 x 480 VGA resolution when streaming to PC
# Magnification: 10x, 60x, 200x
# Light Source: Twin "Superbrite" LEDs
# Memory: Direct to PC (based on PC capacity)
# Video Playback: 15 frames per second
# Power Source: PC when connected
Well I couldn't find it at any of the stores locally that they list, but ran across similar products:
www.pcgears.com/default.aspx?oid=139069&gclid=CIuRmtmM250CFSn6agodwk0ZrQ
Post Edited (Todd Chapman) : 10/26/2009 4:14:16 PM GMT
I got for 55.00
Mine is the Intel Play QX3
It may be a toy but the images look very nice.
I searched and there are several on ebay in the range 10 -30 dollars.
