Raytheon's 'Sum Of All Fears' robotic arm
Just opened at Epcot center...now this would be a fun propeller project
I wonder if large car starter motors could power this?
www.youtube.com/watch?v=ilpBKRwqIsE
"Where am I? Where am I going? Why am I in a handbasket?"
Try Ebay...look for Fanuc.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
I looked for a robotic are strong enough to swing around that much weight.....but didn't find one. I didn't search very thoroughly though.
I'm pretty sure it is a Fanuc or one of the large brands which provided the arm. Pretty scary....because I used to work with those, and have seen when things go wrong. I saw one launch a TV about 400 ft. Not a small TV either.
James L
James L
Partner/Designer
I read about some guy using them as motors in a project.
If I remember correctly he turned them into some sort of giant
stepper motors. They must be strong...they can make a big
gasoline motor spin.
Maybe if you had a large air compressor you could move an arm that big with that?
Don't they do that to make the stuff work on those big tracked vehicles you
see at construction sites?
BTW... I saw the new videos of the twins on your youtube page.
I loved the active baby clip
The one with the baby snoring was precious as well.
You should take lots of footage of you and their mother
holding them....those will be very important to the girls
decades in the future.
You just can't take too many pictures.
I have a short clip of me as a baby with my parents.
I keep meaning to make a digital copy of it for safety
as it is on an old tape that is like 20 years old...it may start
to fade away. I figure if I post stuff like that on youtube
it will become eternal as I can't imagine the vids there
will ever be lost.
You just have to see this video of a baby girl dancing to
a music video!
www.youtube.com/watch?v=ikTxfIDYx6Q
Post Edited (HollyMinkowski) : 10/24/2009 2:44:08 AM GMT
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
So those tubes with the rods in them are full of liquid then?
Since liquid is not compressible like air there must be another
cylinder and rod that has a motor pushing the rod in/out to
squirt out the liquid and then pull the rod to suck it back in?
Those little hoses running to the tubes must be very tough
That digging machine looks like it would be fun to play with.
If you put a seat where the shovel is it would almost be like that
new ride at Epcot! You could sell tickets and join a carnival ... LoL
The liquid is hydraulic oil. The tubes with rods in them are called cylinders. There is a pump attached to the motor which provides the pressure. The pressure in those hoses is about 3,000 psi.
en.wikipedia.org/wiki/Hydraulic_machinery
It is fun. You can search around YouTube and find some crazy things people have done with excavators.
Redneck ride
Dangerous fun
Also dangerous - on a smaller scale
Rowing?
Excavator car wash
Rich H
Post Edited (W9GFO) : 10/24/2009 6:21:17 PM GMT
www.youtube.com/watch?v=Tqd4aPs5WTA
-dan
Arguing with myself--sometimes me, myself, and I don't always agree.
(Former) Caterpillar product support technician
Hydraulics seems like a really excellent way to power robotics.
But I don't see how they prevent fluid leakage and loss under such
high pressures!?
Has anyone ever done hydraulics with a completely closed system?
I mean with something like expandable membranes at both ends
instead of the cylinders and rods? Not as much linear motion but
there would never be any fluid loss.
I was going to try to explain it but the following link does a better job plus it has pictures...
-dan
en.wikipedia.org/wiki/Hydraulic_cylinders
Post Edited (icepuck) : 10/25/2009 12:18:47 AM GMT
I was too, that's why I put the exact same link in my post above...
Rich H
The compressibility of air is a big problem from a safety standpoint, though. In an industrial environment, if a pneumatic actuator jams, the pressure can build up until the jammed component frees itself with explosive suddenness. Hydraulics are much safer in this regard.
My car (a 1982 Mercedes diesel) uses reverse pneumatic (i.e. vacuum) actuation for a bunch of functions, including door-, fuel- and trunk-locks, brake assist, and motor kill. If you lift up the floor mats, you will see plastic vacuum lines running all over the place. In the trunk there's a "vacuum reservoir" ('hafta laugh every time I describe it that way
Quite true about pneumatics, which is one reason you shouldn't try to pressurize air in PVC pipes, etc. The springiness of the air allows more energy to be stored in the system compared to a fluid like hydraulic oil or water, so when a pressurized pneumatic system lets rip, it can accelerate the pieces much faster than a liquid fluid. However, getting a leak in a high-pressure hydraulic line, if it just so happens to be the right size hole, can create a powerful jet that is easily capable of cutting off your fingers or injecting your skull with lots of oil and turning your brains into a pink and grey version of a snow globe. If you've ever used a pressure washer on a piece of wood, you know what I mean.
Yeah, and PVC doesn't just break, it shatters, sending sharp jagged projectiles at you at high velocity.
Rich H
Lay chicken wire over it, spray paint black, then remove chicken wire and it would really look like a fly.
Rich H
Starter motors are not toys, they need huge currents (~100A) and produce quite a bit of torque: If not secured properly they _jump_ when powered, very dangerous.
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
