overkill but done for curiosity
Was curious how close i could make the 12 parallel traces to exactly the same length.
The traces are for hdmi data. I managed to get them to within 3.6pS of each other. kind of silly though since the maximum transfer speed of the controller is 350MHz. and this with tight coupling to the ground plane 5mil below it should be able to do 3GHz.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
this is all a mute point because I forgot i need to put resisters in the middle of each trace and I can easily handle a 33pS delay between first and last bit arriving.
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
On this board I match the HDMI outputs to length exactly but that was easy by placing the driver chip in the right spot. pinout is almost the same as the hdmi header.
I am thinking I will have to drop the 10ohm series resisters do to lack of space. They are intended to help reduce reflections but the only way I can fit them in is to place them on the bottom and use vias which will increase the reflections.
I also need to leave the chip in 12 bit double edge mode which will hopefully work.
