Changing chips...serial not working
Fairly new user to Stamp here, been using PIC for a while.
I had a project with a BS2 and ran into issues with it not being powerful enough. With feedback from the users here I purchased a BS2px to replace it. I changed the model # in my code and uploaded the program to the new chip. Unfortunately my serial communication doesnt seem to be working to my devices (serial computer, serial lcd, and serial dispensing unit) Are there differences in the chips that I need to take into account and change in my program?
#SELECT $STAMP ' Select Baud constants #CASE BS2, BS2E, BS2PE T1200 CON 813 T2400 CON 396 T4800 CON 188 T9600 CON 84 T19K2 CON 32 #CASE BS2SX, BS2P T1200 CON 2063 T2400 CON 1021 T4800 CON 500 T9600 CON 240 T19K2 CON 110 #CASE BS2PX T1200 CON 3313 T2400 CON 1646 T4800 CON 813 T9600 CON 396 T19K2 CON 188 #ENDSELECT Inverted CON $4000 'Value for inverted serial format Baud CON T4800+Inverted '4800 baud, 8,N,1 invertedWhen you say you changed the model number in the code, I assume its for the conditional compiling such as shown in the programming template. Make sure you're also using the code snippet that includes the BS2px. Some of the earlier examples just go up to the BS2p.
Go to the HELP file in the editor and select SEROUT. Down at the bottom of the write up is the current full list for doing conditional compiiling. Copy and paste it into your code.
Cheers,
PS See previous post.
Tom Sisk
http://www.siskconsult.com
