Solder Paste - Where can I get some?
I'm working on a new design, and I'm going the full SMD route this time around. I've found that using a fine tip soldering tip, and wire solder just doesn't do it. So, I'm now looking for a solder-paste syrienge. I'd like to have really good control of the amount, and placement of the solder paste, so I guess a fine tip would be needed.
Does anyone know where to get one? I've looked on ebay, but all the items are either solder paste in a small "can", or jewelry stuff...
manncorp.com
digikey.com
When using syringes, I used these:
www.zeph.com/zephpaste.htm
Look for syringes on that page.
I think you will eventually go to stencils, they make the process so much easier.
Remember, when going to stencils, syringe paste is a little too "thin" for stencils. Jar solder paste is thicker, and works better. We typically have to mix in some flux to get jar paste the right consistency for hand stenciling.
Hope this helps,
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
1: if I use the solder paste in the ad you posted for Phil is that all I have to do or do I still need to heat it after applying I am hoping its like glue and you just glue the part down?
2: MCtriva can you please elaborate I see you post about these but the only stencils I have seen are like stickers you peel and stick them on a board and you can drill holes and solder to them is this the product you are referring to ???
Thanks guys I am finding it way harder to use SMT than I thought, even with an adjustable Iron I end up burning the pads of the carrier boards.
Stencils are laser etched to match the pads on your board.
Solder paste needs to be heated up. Use a convection toaster oven. Run at 200f for 4min, 325 for 2min and then 450 for 30 second.
Post Edited (mctrivia) : 10/20/2009 11:43:29 PM GMT
I try to never touch a board with a iron unless I must. When using an iron rosin core solder (Multi-core) or a brand like that is your friend. Flux is also your friend, but make sure it is no-clean.
James L
James L
Partner/Designer
Thank you
That question is loaded.
The chips are designed to take a certain amount of heat. Most chips will take 260 deg C for at least 10 seconds. SAC305 Solder melts at 218-225 Deg C. So if your careful it will work fine.
If using leaded solder.....no problem. Just set the oven to 400 and when it comes to that temp. The boards will be done.
All surface mount chips are baked on the board to mount them.
James L
James L
Partner/Designer
