display data from two functions from main
i have a few sub functions and i can call them and print from wiuthin the function but i want to display info from more than 1 function on the screen
HERE IS ALL OF MY CODE
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] Revision History ]
[noparse][[/noparse] I/O Definitions ]
Rx············· PIN···· 7············· ' Receiver(27981)DATA pin
TxEnable······· PIN···· 9············· ' Transmitter(27980)PDN pin
Tx············· PIN···· 8············· ' Transmitter(27980)DATA pin
SDA············ PIN···· 3············· ' I2C serial data line
SCL············ PIN···· 4············· ' I2C serial clock line
TxPin·········· CON···· 15
EN····· PIN 0······ ' Connect to SLED4C enable pin #5
[noparse][[/noparse] Constants ]
EOM············ CON···· 255············ ' Value to signal end-of-message
Address········ CON····· $A0··········· ' Address Of 24LC128
Ack············ CON····· 0············· ' Acknowledge Bit
#SELECT $STAMP························· ' Select Baud constants
· #CASE BS2, BS2E, BS2PE
··· T1200······ CON···· 813
··· T2400······ CON···· 396
··· T4800······ CON···· 188
··· T9600······ CON···· 84
··· T19K2······ CON···· 32
· #CASE BS2SX, BS2P
··· T1200······ CON···· 2063
··· T2400······ CON···· 1021
··· T4800······ CON···· 500
··· T9600······ CON···· 240
··· T19K2······ CON···· 110
· #CASE BS2PX
··· T1200······ CON···· 3313
··· T2400······ CON···· 1646
··· T4800······ CON···· 813
··· T9600······ CON···· 396
··· T19K2······ CON···· 188
#ENDSELECT
Inverted······· CON···· $4000·········· 'Value for inverted serial format
Baud··········· CON···· T9600+Inverted· '9600 baud, 8,N,1 inverted
Nak············ CON···· 1······················ ' no ack bit
EE24LC32······· CON···· %1010 << 4
Baud19200······ CON···· 32
[noparse][[/noparse] Variables ]
string········· VAR···· Byte(3)······· 'Array to hold received data
strLen········· VAR···· Byte··········· 'Length of string received
temp··········· VAR···· Byte··········· 'Temporary variable
packet········· VAR···· Byte··········· 'Current packet number
lastPacket····· VAR···· Byte··········· 'Last good packet number
cValue········· VAR···· Byte··········· 'Value to add to CRC value
crc············ VAR···· Word··········· 'Calculate CRC value
rcvdCrc········ VAR···· Word··········· 'Received CRC value
idx············ VAR···· Word··········· 'Index into message data
char··········· VAR···· Byte··········· 'Current character from message
'temp2·········· VAR····· Byte·········· ' Variable Used For Work
'i2cWork········ VAR····· Word·········· ' Work Byte For I2C I/O
'i2cAck········· VAR····· Bit··········· ' Ack Bit From Device
'eeprom_add····· VAR····· Word·········· ' EEPROM Address
cnt············ VAR····· Byte
test··········· VAR····· Nib
ADDR··········· VAR····· Byte
CFG············ VAR····· Byte··· ' Holds display configuration value
Hours·········· VAR····· Byte
Minutes········ VAR····· Byte
Days··········· VAR····· Byte················· ' FOR...NEXT loop index
seconds········ VAR····· Byte················· ' FOR...NEXT loop index
[noparse][[/noparse] Initialization ]
Message DATA "WSN A"
······· DATA EOM
Check_Module:
· #IF ($STAMP >= BS2P) #THEN
··· #ERROR "Use I2COUT and I2CIN!"
· #ENDIF
Setup:
HIGH TxPin ' Set pin high to be a serial port
PAUSE 100 ' Pause for Serial LCD to initialize
BoardID DATA "A1"
·' DEBUG CLS
SEROUT TxPin, Baud19200, [noparse][[/noparse]$0C]· ' clear LCD
SEROUT TxPin, Baud19200,[noparse][[/noparse]"WSN", CR,
", CR,
····· '· "Address...···· ", CR,
······ ' "Output....···· ", CR,
······ ' "Input.....···· ", CR,
····· '· "Status....···· ", CR,
····· '· "Errors....···· ", CR,
····· '· "Light.....···· ", CR,
····· '· "Battery....··· ", CR,
····· '· "Sensors....··· ", CR,
······· "TPacket. ", CR,
······· "RPacket. "]
· '·· GOTO main
[noparse][[/noparse] Program Code ]
main:
DO
GOSUB clock
GOSUB transmit
LOOP
clock:
DO
SEROUT TxPin, Baud19200,[noparse][[/noparse]$86,DEC Hours, ":", DEC2 Minutes, ":",DEC2 seconds] ' display the time ell
PAUSE 1000 ' This may need to be adj for how long it take to run this routine
seconds = seconds + 1
IF seconds = 60 THEN
minutes = minutes + 1
seconds = 0
ENDIF
IF hours = 23 AND minutes = 59 THEN
days = days + 1
ELSE
IF minutes = 60 THEN
hours = hours + 1
minutes = 0
ENDIF
ENDIF
LOOP ' never stop the loop
[noparse][[/noparse] Subroutines ]
Transmit:
' Send the test data to another node
LOW Tx································· 'Initialize transceiver interface
LOW TxEnable··························· 'Disable transmitter
packet = 1····························· 'Initialize packet number
··· DO
· idx = message······················· 'Point idx to start of message data
················ DO
··· strLen = 0························· 'Set string length to zero
··· crc = 0···························· 'Start Crc at zero
··· DO
····· strLen = strLen + 1
····· READ idx, char··················· 'Read a character from message data
····· idx = idx + 1···················· 'Point to next character in message
····· string(strLen-1) = char·········· 'Put character into string array
····· temp = char······················ 'Prepare to add char to Crc value
····· GOSUB CalcCRC2···················· 'Add cValue to Crc value
····· IF (strLen = 2) OR (char = EOM) THEN EXIT ' Exit if done
LOOP······················· 'Keep reading message characters
DO
RecvTimeOut:
····· PAUSE 100························ 'Give receiver time to process
····· SEROUT TxPin, Baud19200,[noparse][[/noparse] DEC packet,$0a,$B1]· ' set num
····· HIGH TxEnable···················· 'Enable transmitter
····· ' Send packet
····· PULSOUT Tx,1200·················· 'Send sync pulse to radio
····· ' Send preample "UUUU!", packet #, string length, string data, crc
····· SEROUT Tx, Baud, [noparse][[/noparse]"UUUU!", packet, strLen, STR string\strLen,
······················· crc.LOWBYTE, crc.HIGHBYTE]
····· LOW TxEnable····················· 'Disable transmitter
····· ' Wait for response from receiver
GetResponse:
····· ' Receive up to 100 characters looking for a "!"
····· ' Use rcvdCrc as temporary variables
····· FOR rcvdCrc.LOWBYTE = 1 TO 10
······· SERIN Rx,Baud,600,RecvTimeOut,[noparse][[/noparse]rcvdCrc.HIGHBYTE]
······· IF rcvdCrc.HIGHBYTE = "!" THEN EXIT
····· NEXT
····· ' If we didn't receive a "!" then timeout
····· IF rcvdCrc.HIGHBYTE <> "!" THEN RecvTimeOut
····· ' Receive the Crc value
····· SERIN Rx,Baud,600,RecvTimeOut,[noparse][[/noparse]rcvdCrc.LOWBYTE,rcvdCrc.HIGHBYTE]
··· LOOP UNTIL crc = rcvdCrc··········· 'Repeat packet until crc match
··· packet = packet + 1················ 'Advance packet value
··· packet = packet MIN 1·············· 'Don't use packet value zero
· LOOP WHILE char <> EOM··············· 'Keep sending until EOM
LOOP···························· 'Start all over at the beginning
Recive:
' recive data from another node
LOW Tx
LOW TxEnable
DO
· ' Wait for preamble, then receive data and crc value
· SERIN Rx,Baud,[noparse][[/noparse]WAIT ("U!"), packet, strLen, STR string\strLen,
················ rcvdCrc.LOWBYTE,rcvdCrc.HIGHBYTE]
· ' Calculate crc of received data
· crc = 0
· FOR temp = 0 TO strLen-1
··· cValue = string(temp)
··· GOSUB CalcCRC
· NEXT
· ' See if received crc value matches calculated crc value
· IF rcvdCrc = crc THEN
··· ' Check if this is a repeated packet
··· IF packet <> lastPacket THEN
····· ' Is last character the "end-of-message" marker ?
····· IF string(strLen-1) <> EOM THEN
······ SEROUT TxPin, Baud19200,[noparse][[/noparse]STR string\strLen ,$0a,$B1] ' set num·· ]·········· ' Display string on debug screen
····· ELSE
······· strLen = strLen -1··············· ' Don't display EOM
······· SEROUT TxPin, Baud19200,[noparse][[/noparse] STR string\strLen,$0a,$B1] ' set num·· ]
····· ENDIF
··· ENDIF
··· lastPacket = packet
··· ' Send acknoledgement back to transmitter
··· HIGH TxEnable
··· PULSOUT Tx,1200
··· SEROUT Tx, Baud, [noparse][[/noparse]"UUUU"]
··· PAUSE 3···························· ' Give transmitter time to process
··· SEROUT Tx,Baud, [noparse][[/noparse]"!"]
··· SEROUT Tx, Baud, [noparse][[/noparse]crc.LOWBYTE, crc.HIGHBYTE]
··· LOW TxEnable
· ELSE
··· ' Received crc did NOT match calculated crc
··· SEROUT TxPin, Baud19200, [noparse][[/noparse]"· ** RECEIVE ERROR **· ",BELL,$0a,$B1] ' set num·· ]
· ENDIF
LOOP
' CRC Checksum Calculation Routine
CalcCRC:
· CValue= crc.HIGHBYTE ^ cValue >> 4 ^ (crc.HIGHBYTE ^ cValue)
· crc = cValue ^ (cValue << 5) ^ (cValue << 12) ^ (crc << 8)
RETURN
CalcCRC2:
· temp= crc.HIGHBYTE ^ temp >> 4 ^ (crc.HIGHBYTE ^ temp)
· crc = temp ^ (temp << 5) ^ (temp << 12) ^ (crc << 8)
RETURN
I2C_Stop:····························· ' I2C Stop Bit Sequence
· LOW SDA
· INPUT SCL
· INPUT SDA··························· ' SDA --> High While SCL High
RETURN
I2C_Start:···························· ' I2C Start Bit Sequence
· INPUT SDA
· INPUT SCL
· LOW SDA····························· ' SDA --> Low While SCL High
RETURN
Addrs:································ ' I2C Address Byte Sequence
·' i2cWork = eeprom_add
· 'SHIFTOUT SDA, SCL, MSBFIRST, [noparse][[/noparse]i2cWork.HIGHBYTE\8] ' Send Byte To Device
·' SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]i2cAck\1] ' Get Acknowledge Bit
·' SHIFTOUT SDA, SCL, MSBFIRST, [noparse][[/noparse]i2cWork.LOWBYTE\8] ' Send Byte To Device
RETURN
Control_Byte_Write:··················· ' I2C Control Write Byte Sequence
·' i2cWork = Address
·' i2cWork.BIT0 = 0···················· ' Sets Unit To Write
·' SHIFTOUT SDA, SCL, MSBFIRST, [noparse][[/noparse]i2cWork\8] ' Send Byte To Device
RETURN
Control_Byte_Read:···················· ' I2C Control Read Byte Sequence
·' i2cWork.BIT0 = 1···················· ' Sets Device To Read
RETURN
Write_Data:··························· ' I2C Write Byte Sequence
·' i2cWork = temp
· 'SHIFTOUT SDA, SCL, MSBFIRST, [noparse][[/noparse]i2cWork\8] 'Send Byte To Device
RETURN
' {$STAMP BS2}
' {$PBASIC 2.5}
· #CASE BS2SX, BS2P
· #CASE BS2PX
#ENDSELECT
······· DATA EOM
Check_Module:
· #ENDIF
Setup:
BoardID DATA "A1"
·' DEBUG CLS
", CR,
· '·· GOTO main
main:
DO
GOSUB clock
GOSUB transmit
LOOP
clock:
DO
seconds = 0
ENDIF
days = days + 1
ELSE
hours = hours + 1
minutes = 0
ENDIF
ENDIF
Transmit:
··· DO
················ DO
··· DO
DO
RecvTimeOut:
····· ' Send packet
GetResponse:
····· NEXT
Recive:
LOW Tx
LOW TxEnable
DO
· crc = 0
··· GOSUB CalcCRC
· NEXT
····· ELSE
····· ENDIF
··· ENDIF
··· HIGH TxEnable
··· PULSOUT Tx,1200
··· LOW TxEnable
· ELSE
· ENDIF
LOOP
CalcCRC:
RETURN
CalcCRC2:
RETURN
· LOW SDA
· INPUT SCL
RETURN
· INPUT SDA
· INPUT SCL
RETURN
RETURN
RETURN
RETURN
·' i2cWork = temp
RETURN
Mike2545
This message sent to you on 100% recycled electrons.
i want to display
SEROUT TxPin, Baud19200, [noparse][[/noparse]" ** RECEIVE ERROR ** ",BELL,$0a,$B1] ' set num ]
but the line of code that states
that is in another function/ SUB
You also have too many threads on the same or similar issues, next time think before you post and then post ONE good thread and get your answers there.
- Stephen
Post Edited (Franklin) : 10/20/2009 2:52:10 AM GMT
In this case, your program is partly hanging up because you're using a solution you've been given that's intended for other situations. It won't work for the situation you've now presented.
sorry for asking the questions i missunderstood how i can ask questions, so i can open 1 thread and ask as many questions as i need in that thred.i will start to do that but how do i name my subject if there are more than 1 topic in 1 thread?
