Zener shunt regulator - was 'Is my Zener broken' (it's not)
W9GFO
I have exactly one 5.1V zener diode to experiment with. I dug it out of an old Radio Shack electronics kit. I have breadboarded a simple circuit so that I can see how it behaves and if it will work the way I want. I'm using a 12V power supply going into a pot to adjust voltage.
My understanding is that if there is 4 volts applied to the reversed biased 5.1V zener that it should show no voltage across the 1K resistor that connects it to ground. Instead I show 50mV. At 4.98V input it increases to 360mV.
Do I just have a crappy zener or is that typical behavior?
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Post Edited (W9GFO) : 10/18/2009 12:34:08 AM GMT
Rich H
Rich H
I learned that adjusting voltage by way of a 5k ohm trimpot to mV resolution seventy times may not have been the best usage of my time. I am going to change my plan slightly and use the zener as a shunt regulator since it will not work as I originally intended due to it "turning on", if only slightly, before it's breakdown voltage.
I also learned that zener diodes are not quite what I had understood them to be. Which is to say they are not devices which only conduct once a certain voltage is reached.
Thanks for the help,
Rich H
The LCD needs about 4.3 volts to be readable so if I have a five volt battery pack as the power supply I am left with 4.3 volts after going through the protection diode. That would work out quite well except that sometimes the input may be up to nine volts so there needs to be some regulation. It is looking like I can just ditch the 5 volt regulator and instead use the zener to shunt any excess voltage. It is a little wasteful at higher voltages but usually the input power will be 5 to 6 volts.
Anything wrong with that approach?
Rich H
· -- Carl, nn5i@arrl.net
It was a genuine "teachable moment."· Some people pay good money for this sort of thing, mon ami.
It sounds like you really need a buck/boost switching regulator. This will take voltages both above and below some design voltage and transform them to a well-regulated output at the design voltage. It's not as simple as a resistor and a Zener plus a transistor switch plus a linear regulator, but, when you're done, it'll work better.
Here's one example: focus.ti.com/lit/ds/symlink/tps55065-q1.pdf
Well there were two measurements for every 200 mV right? I did cheat a bit and skip the measurements from .4V to 1.6V since there was no change between .2V and 2.0V (I skipped zero too). I should have said that I adjusted the voltage 28 times and took 56 voltage measurements, no, that wouldn't be accurate either because many of the measurements were repeated. I guess I shouldn't have said anything.
Hmmm, now I am wondering... I had already learned that my zener leaked more current as the voltage increased (prior to reaching the breakdown voltage) before you requested the data points. Perhaps I have missed your point and not learned what you had intended. It wouldn't be the first time that a concept sailed over my head.
I can add that I was also under the misconception that once a zener reached it's breakdown voltage it would allow that voltage to pass through it, unhindered. Instead, that voltage is consumed by the zener. It would have made more sense to me if a zener was described as a device that would drop a certain voltage through it (when reverse biased) equal to it's zener rating.
Apparantley, I am still a noob.
Rich H
Of course now I desperately want hook up a diode and start measuring voltages.
I've looked into those before, so many pins!
I tried this simple circuit;
It seems to work ok using a 68 ohm resistor. I can see a disadvantage in that if the zener has a bad connection there will be no regulation other than the current limiting provided by the resistor. Also, my 5.1V zener allows the voltage to climb to 5.3V when the input is 8V. Maybe I need a lower value resistor, I don't have the specs for the current draw of the LCD so it is trial and error with the resistor value. A tighter tolerance zener would help too I'm sure.
Rich H
The Wikipedia is your friend: en.wikipedia.org/wiki/Zener_diode
Zeners are not great voltage regulators for some of the reasons you've noted. They're pretty good voltage references where the amount of current needed is small and relatively stable.
Forgive me for being dense, but I am not understanding.
I only wish to use the zener to regulate (limit) the voltage going to the LCD, which is tolerant of a slightly variable voltage, everything else on the board gets regulated 3.3V. To use a buck/boost converter would require a high pin count chip, several resistors, capacitors, inductors and a shottky diode plus a fair bit of real estate on the PCB - all to provide a steady 5.0V to exactly one point. Is that really the most sensible approach? My first choice would be to use a 3.3V LCD but that is not an option at this point.
The zener is not ideal but seems like it would do the job. Other than the reasons noted, which are tolerable I think, would it be bad to use this method?
Rich H
They only cost $8.00 per board
http://www.futurlec.com/Mini_Power.shtml
[url=:popitup('../Pictures/ET-MINI_POWER_SUPPLY_600.jpg')]
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 10/17/2009 9:00:21 PM GMT
1) current increases, and
2) the input voltage increases
They're cheap (maybe 25 cents each in a multi pack), ultra-simple to use (3 pins), deliver excellent regulation, and perfect for a low-current LCD display, even for a battery-powered device.
I picked up some zeners from RS. They can handle 1 watt but require 49mA, much more than the typical 5mA ones I found on Mouser. Using it along with a 47 ohm resistor is working nicely. I'll order some 5mA ones so as not to waste so many electrons. This LCD has no backlight but if it did I think I would be able to power it via the regulated 3.3V.
Rich H
Here is a basic regulator using a Zener.
www.elecfree.com/electronic/misc-regulator-circuits-by-2n4401/
Beau Schwabe
IC Layout Engineer
Parallax posesses power beyond belief.
Believe in it.
Visit me at
http://jrelectromech.services.officelive.com/default.aspx
Rich H
Believe in it.
Visit me at
Rich H
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
