Rev C USB2SER Adapter
Just got mine in the mail today. There are no indications on the device as to which pin is which. Also, do the Rev B docs match Rev C?
Shawn Lowe
When all else fails.....procrastinate!
Shawn Lowe
Shawn Lowe
I know that Rev B was a major redesign using a different (newer and simpler to use) FTDI chip. I don't know anything about Rev C. I would suspect that there's nothing obviously different from the customer's standpoint. There is a top surface and a bottom surface and I suspect the schematic refers to the connections seen from the top. I don't have a Rev C, but there must be a painted dot next to pin 1 of the output connector.
Shawn Lowe
Chris Savage
Parallax Engineering
50 72 6F 6A 65 63 74 20 53 69 74 65
Shawn Lowe
The connections are silk screened on to the PCB. Look for the 'VSS', 'RX', 'TX', and 'RES' labels for ground, receive, transmit, and reset, respectively. They are also shown in the diagram labeled 'Top View' on the first page of the documentation.
Electrically, Rev B and Rev C are identical, and the same documentation refers to both. The link on the web page was outdated, and I just had it updated to reflect both Revs B and C.
Let me know if you have any other questions,
David Carrier
Parallax Inc.
I checked mine, there are no connections silk screened on the device. However, if it is electrically the same as the Rev B, then I'm good to go! Thank you.
Shawn Lowe
