SEROUT problem with Sparkfun Serial LCD?
Hi,
I'm having a problem using the SEROUT command with a Sparkfun serial LCD 16x2.
The Datasheet says that in order to write a custom boot splash screen, set the display how I want it, then send the 'special' control character 0x7C (dec 124) followed by "<control>j".
I have no problem sending any other of the commands or displaying text but I don't understand what it means by "<control>j".
Doing:
Simply displays <control>j on the LCD?
Datasheet can be found here: www.sparkfun.com/datasheets/LCD/SerLCD_V2_5.PDF
Has anyone else come across this or could anyone please shed some light on the subject?
Many Thanks in advance,
Morrolan
Flying is simple. You just throw yourself at the ground and miss.
"I think computer viruses should count as life. I think it says something about human nature that the only form of life we have created so far is purely destructive. We've created life in our own image."
Stephen Hawking
Doing:
SEROUT 10, LcdBaud, [noparse][[/noparse]$7C, "<control>j"]
Morrolan
Stephen Hawking
' {$STAMP BS2} ' {$PBASIC 2.5} lcd PIN 4 lcdCom CON $FE 'command prefix lcdCom2 CON $7C 'special command prefix clrLCD CON $01 'Clear entire LCD screen displayOff CON $08 'Display off displayOn CON $0C 'Display ON noCurs CON $0C 'Make cursor invisible ulCurs CON $0E 'Show underline cursor blkCurs CON $0D 'Show blinking block cursor curpos CON $80 'set cursor + position (row 1=0 TO 15, row 2 = 64 TO 79) scrollRight CON $1C scrollLeft CON $18 curRight CON $14 curLeft CON $10 #SELECT $STAMP ' Select Baud constants #CASE BS2, BS2E, BS2PE T1200 CON 813 T2400 CON 396 T4800 CON 188 T9600 CON 84 T19K2 CON 32 #CASE BS2SX, BS2P T1200 CON 2063 T2400 CON 1021 T4800 CON 500 T9600 CON 240 T19K2 CON 110 #CASE BS2PX T1200 CON 3313 T2400 CON 1646 T4800 CON 813 T9600 CON 396 T19K2 CON 188 #ENDSELECT PAUSE 500 SEROUT lcd, T9600, [noparse][[/noparse]lcdcom, clrLCD] SEROUT lcd, T9600, [noparse][[/noparse]lcdcom, curpos+6, "First", lcdcom, curpos+68, "LastName"] SEROUT lcd, T9600, [noparse][[/noparse]lcdcom2, $0A] 'ctrl-jMany Thanks,
Morrolan
Stephen Hawking
