RfID with BS1-IC — Parallax Forums
RfID with BS1-IC
oconocon Posts: 2
edited 2009-10-17 14:40 in BASIC Stamp
Hello everybody,
I need some help here as I dont understand how the tags are stored into the EEPROM. If I run the sample program that displays the tag ID· (http://www.parallax.com/Portals/0/Downloads/src/prod/RFIDBasic1.zip) I get the ID as:
51 65 48 48 48 54 57 57 67 56
But if I store that number into the EEPROM with the other .bs1 example program (the one on http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol6/col/nv120.pdf·) It says that the Tag is unknown.
I tried to convert it from decimal to HEX with a calc, but it wont work either. How can I use the tag ID's (or convert them if needed) in order to be used with my application?
Thank you all for your support,
Ocon
  • TumblerTumbler Posts: 323
    edited 2009-10-17 07:05
    Hello Ocon,
    Please post your second program here, so we can take a look at it.
    edited 2009-10-17 07:15
    ocon,
    The numbers reported back appear to be ASCII ... that's ok.. the conversion is different than what you would do for HEX.
    ASCII to Decimal:
    Rule #1) If the value is less than 58 subtract 48 and that is the decimal number.
    Rule #2) If the value is greater than 64 subtract 64 and that is the place holder for the letter in the alphabet.
    For example with your numbers....
    51 - Apply Rule #1 - 3
    65 - Apply Rule #2 - 1 -> A <- 1st letter in alphabet
    48 - Apply Rule #1 - 0
    54 - Apply Rule #1 - 6
    57 - Apply Rule #1 - 9
    67 - Apply Rule #2 - 3 -> C <- 3rd letter in alphabet
    56 - Apply Rule #1 - 8
    ...So the value to place in EEPROM is ... 3A000699C8
    EEPROM ("3A000699C8")
    Beau Schwabe
    IC Layout Engineer
  • oconocon Posts: 2
    Thank you Beau,
    I this seams to be the answer [noparse]:)[/noparse] I will try it in the next hours and let you know the outcome. I found this table to ease the conversion:
    http://easycalculation.com/ascii-hex.php
    Thank you again,
    Ocon
    Beau Schwabe (Parallax) said...
    ocon,
    ASCII to Decimal:
