Software Sugestions for making PCB Panels
I design my boards in Eagle and would like to take several projects and panelise them on to a 7x10 panel.· I could do in eagle but this would limit me to keeping all the board clearances the same in all projects and i would have to be very careful that my copour pores do not exced the boarders.· I do not want to be stuck with these limitations so I am looking for a software package that can take gerber files from several projects and make a 7x10 panel for me.· Preferably with me just needing to set the router width and it doing everything automatically but manual would work also.
Any ideas?
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Any ideas?
Pentalogix has the best software for the price. It is a little hard to learn, but it can do the job. Viewmaster EZ is what you are looking for.....not too expensive....
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
Not really.....the components in eagle get renumbered when panelized. But it does depend on the method.....there are other ways, which I have never tried.
I use Diptrace, so i do not have that problem.
James L
James L
Partner/Designer
Next, copy the entire board from each project into a new paneled version board. The resulting copy on the new 'multi-board' will be exactly as it was on the individual file, and will NOT be subject to design rules of the new board. Once you route a board and paste it elsewhere, the design rules of the result board are no longer acting on the pasted board. However, you cannot make changes to the multi-board, you must always go to the original board file to make changes, then copy the board back to the multi panelized board. Just select the entire board and hit the scissors button, then on the new board do the paste, slide the board to a location. Be sure to have already done your copper pour for top and bottom on the original files.
James Long: That program would be perfect I just don't have $500 at the moment. Putting all my money into the PCB panel. 4 layer, 4mil clearance is not cheap.
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
National Instruments Multisim to be specific
Parallax posesses power beyond belief.
Believe in it.
Visit me at
http://jrelectromech.services.officelive.com/default.aspx
Post Edited (Lab Rat) : 10/17/2009 3:03:47 AM GMT
The only think I can suggest then is to get the paid version of Viewmaster EZ, then load in the separate boards to a panel board, output files as needed to the PCB house.
Gerbmerge - I use it all the time. Now that I know how to use it. It's quite simple. But the first time I used it....
It's written in Python, so your need to install Python and a few other support programs. The you run it in a command line (if you are using Windows), from there, there are 2 text files you edit to make things happen, there is no GUI.
Best thing about it is that it's free
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
