Bitmapped NTSC driver?
Bill Henning
Has anyone written a pure bitmapped NTSC driver?
160x100 or 160x120 would seem quite doable (even without Morpheus <grin>), and be of a reasonable size even with a full byte per pixel.
As I recall, there are 228 color clocks per scan line, and 262.5 lines per field... ignoring overscan areas, front&back porch and sync areas, 160x120 would seem to fit nicely by "double scanning" each line on each field.
Actually, a four color bitmapped driver with a separate palette per scan line (or 8 scan lines) would be even better... much less memory required!
I'd write it, but I am a bit busy right now... and I am sure someone has done it already!
The reason I want something like this is to put one of my 3.5" NTSC displays onto the robot I am building for a "face" and status...
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
Post Edited (Bill Henning) : 10/14/2009 10:18:25 PM GMT
I've only been using the VGA drivers and TV tiled drivers so far; I thought I remembered that the TV graphics object rendered into tiles, not a contigous bitmap.
Now after you pointed me at it, I checked the source... and what do you know... it uses a real bitmap [noparse]:)[/noparse]
Mea Culpa.
Post Edited (Bill Henning) : 10/14/2009 10:49:56 PM GMT
If a sequential set of tiles addresses are defined, the Parallax driver makes a nice bitmap. It's just not a simple linear addressable one, and that perhaps explains mpark's comment.
It also uses the better color timing, so it's good for 320+ pixels.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
I will check it out... either that or graphics.spin will work for me.
Be sure and use the color map you will find. There is no color redirection, so 00 = sync.
Found it.
