I am using uarts 0,1,2,3,4 on the Javelin.
I tried using·5 and it throws an exeption.
Do you know if i reached the limit·and If so
can that be extended?
You can run 6 VP's simultaneously, eg. 6 uarts, 5 uarts + Timer, or
any other VP combination.
You can declare more than 6 uarts. Stop one uart to start another.
I usually use
VP0 = Timer
VP1 = transmit uarts (I only keep 1 TX uart running at any time)
VP2,VP3,VP4,VP5 = receive uarts and other VP (like PWM, DAC, ADC)
I usually use
VP0 = Timer
regards peter
Stopping one and starting another is
the key I was looking for!
Thank you as always!
Jeff
