Allowing an end user to select the program that runs on a sealed project (bootl
WBA Consulting
My project outline:: Upon power up or reset, an LED goes solid. The user holds a button down and the program slowly cycles through a single blink, double blink, and triple blink and the user releases during one of those cycles. If the LED was in it's double-blink cycle when the button was released, the program "2.bin" from the SD card is started on the prop as the active program and while running, the double blink becomes the "power on" LED status.
Where's the best place for me to start to create a "bootloader"?
I am currently looking into:
PropDOS
PROPCMD
Any other ideas? Recommendations for this venture? Things to avoid?
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
Post Edited (WBA Consulting) : 10/14/2009 6:42:45 PM GMT
PropDOS
PROPCMD
Andrew Williams
WBA Consulting
another idea is to place the EEPROM into a plug: plug-in the right EEPROM and there we go.
If you would like the user to load a lot of different programs the SD-card is a good way to go.
I haven't tested any bootloaders yet so I can't give advice on that. But if I remember right femto-basic has some kind of a bootloader
best regards
Stefan
Andrew Williams
WBA Consulting
What I did a while ago is using 2 EEPROMs and switch the adress pins of the EEPROM. In that way you can select the program that's been booted. Of course you can also have an additional EEPROM and a rotary switch to select the EEPROM used for booting.
If you insist on selecting a program from SD-card, the SD-card driver (fsrwFemto from ObjectExchange) includes a function to boot an image from SD-card.
