Servo Controller Protocol, is there a -de facto standard- or does everyone have
In Cypress PSOC Appnote AN15054 for a 20 channel PWM Servo Controller, the author makes a statement that I believe is inaccurate in regards to protocols used for servo controllers, but I wanted some opinions from people who actually have more experience with servos (I just started playing with servos connected to a BS2 this weekend). The appnote states:
The Mini SSC II protocol of Scott Edwards Electronics Inc. has become the de facto standard for multi-channel serial servo controllers.
I did a quick search and the only one I found using the SSC II protocol is the one made by "Scott Edwards Electronics Inc" (SEETRON SSC). There is some software out there that uses this standard, but I believe it's so the software has a wider market.
Is this statement in the appnote purely opinion of the author?
On a side note, I think the 20 channel serial servo controller in the appnote would work great with any Parallax microcontroller and even RobotBASIC. My to-do list now has a line for trying this out on breadboard since I have a PSoC programmer some of those chips in a DIP-28 package.
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
Andrew Williams
WBA Consulting
So, assuming it is the serial communication with the controller then the protocol simply refers to the command set and structure of commands sent and at what baud rate and other serial settings. In that case it well be an opinion of the author, since there are many different servo controllers available. Take care.
Chris Savage
Parallax Engineering
50 72 6F 6A 65 63 74 20 53 69 74 65
And he gives this as the reason why standard servos require 1 to 2 ms pulse widths at 50 hz?
What am I missing here?
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
The only way it would make sense (and not the way I would do it) is if you started the pulses at the same time and the 8-bit value contained the duration of the pulse, plus the remainder of the period, which isn’t necessary on servos.
Chris Savage
Rich: Good catch. I have found a few other things in the appnote that seems a little off.
I did load the program from the appnote into a CY8C27443 chip and it actually works well with the windows app in the zip file. I'll be trying it out with a BS2 this weekend. If it works, that will be a 20 channel servo controller for $6.50.
Andrew Williams
WBA Consulting
