Fire resistant resistors?
How do you determine if the resistors you buy are fire resistant?· I bought some cheap resistors online and then I learned they could be from another country and then I learned I could buy fire resistant resistors.· How do you tell and can you always know?
http://en.wikipedia.org/wiki/Fire-resistance_rating
http://www.freepatentsonline.com/3804669.html
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Tia'Shar Manetheren
· -- Carl, nn5i@arrl.net
At 3.3 - 5.0 volts, there isn't much of a fire risk. Of course if you are building a hefty power supply or driving horsepower multiples of motors, use the fuses and circuit breakers. If a circuit calls for a 3 watt resistor, use a 5 watt.
What the heck is an 'emergency type' circuit? A hazardous environment is more likely to call for fire prevention.
I would suspect that fire retardant resistors are more appropriate for highly combustible environments and atmospheres - like in a gas station. These applications have specialized ratings and go through extensive testing toward certification. Just adding the resistors isn't going to get you a certification for safety in such. The whole process is expensive and meant to be so that well heeled corporations can dominate the market.
Regarding 'combustible environment'.... that was the reasoning behind a metal chassis and metal conduit. The chassis and conduit are intended to contain any fire created by an electrical failure. The fuse is suppose to eventually make the system fail into an 'off mode'.
Post Edited (Loopy Byteloose) : 10/14/2009 2:29:09 PM GMT
humanoido
