Using RFID to change subroutine of robot.
Hi,
For a school project we are programming a Boe-Bot which uses the Line Rider for navigation.
Also we want it to navigate by just using code.
We mounted a RFID reader underneath the robot and now we want it to Follow a line and at the same time check for any RFID tags in on the ground.
The code we are using right now wil ride a line but when its going to check for a RFID tag it stops. We want it to continue riding the line as long as there is no RFID tag.
Could someone please help us. We have been cracking our heads on this for two full days now...
Our Code so far:
Our Code so far:
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[noparse][[/noparse] I/O Definitions ]-------------------------------------------------
Enable PIN 0 ' low = reader on
RX PIN 1 ' serial from reader
Spkr PIN 2 ' speaker output
led PIN 3 ' Led Light
' -----[noparse][[/noparse] Constants ]-------------------------------------------------------
T2400 CON 396
' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
buf VAR Byte(10) ' RFID bytes buffer
idx VAR Byte ' tag byte index
qtis VAR Nib ' Line follower
counter VAR Byte
' -----[noparse][[/noparse] Initialisation ]---------------------------------------------------
OUTB = %1111
' -----[noparse][[/noparse] Program Code ]----------------------------------------------------
main:
DO
GOSUB rfid
PAUSE 1
GOSUB line_rider
PAUSE 1
LOOP
line_rider:
FOR counter = 1 TO 16
GOSUB Check_Qtis
DEBUG CR, "Riding Line...", CR
DEBUG BIN4 ? qtis, CRSRUP
SELECT Qtis
CASE %1000
PULSOUT 13, 650
PULSOUT 12, 650
PULSOUT 14, 1050
CASE %1100
PULSOUT 13, 750
PULSOUT 12, 650
PULSOUT 14, 1050
CASE %0100
PULSOUT 13, 800
PULSOUT 12, 650
PULSOUT 14, 1050
CASE %0110
PULSOUT 13, 850
PULSOUT 12, 650
PULSOUT 14, 1050
CASE %0010
PULSOUT 13, 850
PULSOUT 12, 700
PULSOUT 14, 1050
CASE %0011
PULSOUT 13, 850
PULSOUT 12, 750
PULSOUT 14, 1050
CASE %0001
PULSOUT 13, 850
PULSOUT 12, 850
PULSOUT 14, 1050
CASE ELSE
PAUSE 5
PULSOUT 14, 1050
ENDSELECT
NEXT
RETURN
rfid:
LOW Enable
SERIN RX, T2400, [noparse][[/noparse]WAIT($0A), STR buf\10] ------------!!** Right now It just stops here because it can't find a tag **!! We just want it to continue riding the line...
HIGH Enable
FREQOUT Spkr, 50, 3400
HIGH led
FOR idx = 0 TO 9
DEBUG buf(idx)
NEXT
PAUSE 1
LOW led
RETURN
Check_Qtis:
DIRB = %1111
PAUSE 0
DIRB = %0000
PAUSE 0
qtis = INB
RETURN
Could you please tell me what this: ($0A) refers to? It's used in the 'WAIT' label, but how do I modify this to make it wait for 1/100 sec or a second are whatever time period I need.
It's is not described in my manual "BASIC STAMP Syntax and reference MANUAL" it's the only manual we have at our school.
In this manual this is what is described about
Timeout:
is an option variable/constant/expression (0-65535)
that tells SERIN how long to wait for incoming data.
If data does not arrive in time, the program will jump
to the adress specified by Tlabel
[noparse][[/noparse]i[noparse][[/noparse]Tlabel:
is an option label that must be provided along with Timeout,
indicating where the program should go in the event that data
does not arrive within the period specified by Timeout.
Next problem:
How to make the label direct to another subroutine... STR buf\10
Right now it's sending to a string where the DATA of the RFID tag is stored right?, please correct me if I'm wrong.
Please help us..
The Tlabel is used for a GOTO if the Timeout is exceeded. You'd do something like:
rfid: LOW Enable SERIN RX, T2400, 250, nothing, [noparse][[/noparse]WAIT($0A), STR buf\10] ' wait at most 1/4 sec for data GOTO doMore nothing: for idx = 0 to 9 ' Make buf look invalid buf(i) = $00 next doMore: HIGH EnableIt's working like a charm!!
You Rock! [noparse];)[/noparse]
Thank you very very much.
When we finish our project I will put some vids and pics online.
Again, thank you for your help.
Kind Regards,
Chris
