USB chip - know of any?
Hi Everyone,
I am wanting to create a USB HID (Human Interface Device) using the propeller chip, obviously the propeller doesn't have the speed required to do USB communication so I was wondering if anyone knew of a chip that can be used with the propeller to allow it to act as a USB HID.
I was looking at the Cypress USB chips and they look promissing but with little documentation I am worried about buying one and not knowing where to start.
Thank you
Building Blocks To The Propeller Chip A web site designed to help people who are new to the propeller chip.
Guitar Hero controller using the prop (WIP) --> HERE
Thank you
Thank you for your speedy reply.
Is there any examples available for this?
edit: where did he go?
lt's not particularly silly, is it?
Style and grace : Nil point
Am looking at it now.
Will let you know how I go
AVR's cheat and ignore the CRC on all inbound packets.. nasty stuff.
I noticed that everything it types is hard coded. I need to be able to
detect a button press ---> send command
For me? relatively easy if I had the time to sit down and get into it.
For you? A good challenge [noparse]:)[/noparse]
I don't understand why FTDI or someone doesn't produce an HID chip. It could have a predefined set of reports, or there could be a couple of chip options that way. While it is not that difficult to create your own using a pic18 or the like, it really doesn't do much good outside your own use.
Why try and beat a square peg into a round hole? If you use a serial device like the ftdi, your device might work (for certain definitions of work) on some variants of Windows that you have around to test with. If you use HID properly it will work on pretty much any OS/Machine you plug it into.
